C6 steering wheel in a C5??
Is there any way to swap the C6 steering wheel into the C5? I rented a new 2012 C6 while I was out in LA for my sister's wedding last weekend and love the steering wheel....although much prefer everything else about my C5 Z06
There isn't anything currently that I'm aware of, I would also really like this. I spoke to John Caravaggio at Carlisle last year and he said he was looking into it, but I haven't seen anything yet. I'd love one of the Caravaggio or Apsis carbon fiber 3-spoke C6 wheels, so I'm hoping something comes out eventually.
Not so, and even if they could fit, the airbag wouldn't work.
This idea is dead, and I got it straight from the horse's mouth!
...and I would love a 'working' C6 wheel/bag in my car.
Only alternative is a 'Raid' SW.
The C6 steering wheel is not compatible for 2 reasons. The first reason is that the spline of the C6 wheel is smaller than that of the C5. The C6 spline size is 0.630 with 36 teeth while I can't rememberwhat the C5 spline size is right now. The 2nd reason is that the airbag system on the C6 is a 2 stage while a C5 is a single stage.
The only known non original Airbag wheel for the C5 is from a German company called Raid. The wheels have become very popular in America with the Porsche, BMW, and Lotus people and can be purchased online through Porsche tuners. The harder part is finding a Raid steering wheel adapter that works with a C5. There is a German company that specializes in Corvettes that used to sell the adapters as well as steering wheels. I think they charged like 200 euros for the adapter.
One other challenge is determining what does it take to successfully wire the Raid airbag with the C5 airbag module. Based on some of the articles I have found online, if both systems are single stage(which in our case they are) than it's direct plug and play. If you are replacing a dual stage with a single stage(i.e. replacing a C6 wheel with a Raid wheel) you need to put an inline resistor into the 2nd stage to trick the computer into thinking it sees 2 airbags. If you look at the links I have provided of how the people hooked it up it looks a lot easier than one would think.
I am currently living in Germany until January so I'm hoping I can get in contact with the Corvette tuner here in Germany to find out whether the Corvette compatible adapters are still available and if it the Airbag really is plug and play. If that doesn't work out, I'm tempted to attempt a conversion of an existing steering adapter hub to one that fits the Raid wheel. If it gets to this point however I am wondering why bother having an airbag based on all the data out there that they do nothing to save lives.
Raid wheel in C5:
Link to steering wheels: http://www.fvd.de/de/en/Porsche-0/-/-/-/group/show/VID_16493398-VCD_36773901-gid_355-sort_4-display_50/Sport_Airbag_Steering_Wheel.html
http://www.carnewal-europe.com/main.htm
Link to German Corvette tuner: http://www.corvetteproject.de/
Single Stage Lotus Steering Wheel Conversion: http://www.lotusenthusiasts.org/Down...ll/Default.asp
Dual Stage BMW Steering Wheel Conversion: http://www.zroadster.net/forum/viewtopic.php?t=23787
Raid wheel in C5:
These pics are of my friend 'JR's car on the German corvettefrum.de.
Raid wheel in C5:
Raid wheel in C5:
yea I looked at the DSV wheel....to me it just looks like an over inflated version of the original
Exactly. That above model shown looks goofy, and still uses the cheap-looking vinyl center cover. If I absolutely HAD to have an airbag wheel, I would kick out the coinage for the Raid.
Hi,
as Frank already posted I have the Raid steering wheel with 12,5'' diameter in my C5 and my C6 Z06.
In both cars airbag covers have been coated with leather and a stitched C5 resp. Z06 emblem which gives a much more better look on the wheel. This mod has no effect on airbag functionality.
Above there are some pictures of my C5 posted by Frank and SoDiezl350 but they are without the replaced airbag cover. Today in the evening I'm going to take some actual photos and post them here.
Werner Moll at www.corvetteproject.de is building the hubs, airbag change is nearly plug and play.
Regards
JR
Regards
JR
Hi,
In both cars airbag covers have been coated with leather and a stitched C5 resp. Z06 emblem which gives a much more better look on the wheel. This mod has no effect on airbag funcitonality.
Regards
JR
Regards
JR
Here we go!
C5:
C6 Z06:
May be C5 logo could be placed a little more deeper on airbag cover. Raid sticker on C5 steering wheel was removed easily but on the second steering wheel there was a small indendation for the sticker and so I had to replace it by another one.
In order to produce the hub an original steering wheel needs to be destroyed due to use of toothing with cross-cut in the new hub.
But technical details about hub and airbag wiring should be díscussed with Werner. He is the expert - I'm just a very satisfied user.
Riding pleasure - especially in combination with the sport seats in the Z06 - has dramatically improved. I would never drive a modern Corvette without these small steering wheels.
Regards
JR
C5:
C6 Z06:
Regards
JR
