Anti-Venom 6 Speed Shifter Modification (Procedure)
Old 09-09-2011, 09:07 PM
  #41
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Originally Posted by 401K Z06
Toque, you are one awesome supporter. I installed one washer today, with noticeable improvement. I will install the second one and compare results.
Thanks for sharing your knowledge and expertise.
Rich
Rich:
Your welcome, and thanks !
I always try to give back when I can...
I'm sure we are all wanting to hear your impressions of having 2 shims in there !
Toque
Old 09-10-2011, 12:38 AM
  #42
yaknow
yaknow's Avatar
Thanks for reviving this thread, I installed the 1st edition of the C6Z06 shifter in my car. While a vast improvement over the C5 shifter, there is still a little issue between 1st and 2nd, will try this as I love the shifter over the original.
Old 09-10-2011, 10:49 AM
  #43
flynbyu2
flynbyu2's Avatar
St. Jude Donor '10
I just did this mod to my car yesterday and WOW what a difference. Much smoother shifting.
I used an aluminum oil drain plug washer which I thought might match up better up against the transmission.
ArmchairArchitect (02-09-2022)
Old 09-10-2011, 04:28 PM
  #44
TriniJoe
TriniJoe's Avatar
I completed the mod today, and it made a difference with my ripper, but I will try a 2nd gasket to see if 2 gaskets are better. My 1st difficulty was finding the gaskets. I visited about 6 auto parts store (including Auto Zone, Advance Auto, Pep Boys, Napa) & none had the Oil Tite gaskets 65277. After some research on the internet, I found that the Napa BK 704-1357 is the same gasket. I went to Napa & purchased 2 for $1.10 each. The other issue was finding the plug on the trans, it was located way up on the top side, not easily seen. Is there a difference with the location of the plug between the 98 & the later model vettes? Then I had an issue with breaking loose the plug, I need a breaker bar to loosen the plug on the trans. I did not have a 15/16" socket but the 24mm fits perfectly. This is a good mod because now I do not have to get rid of my ripper. Thanks.
Old 09-10-2011, 11:00 PM
  #45
tlove32
tlove32's Avatar
Just did this mod today...I didn't notice much of a difference (MGW shifter), but I only drove around the block. I'll drive it more and post back.
Old 09-10-2011, 11:32 PM
  #46
flynbyu2
flynbyu2's Avatar
St. Jude Donor '10
I can get aluminum oil drain plug washers for 85¢ each. If anyone's having trouble finding these, I can send 'em out for $1 (ea) shipped.
Old 09-11-2011, 03:30 PM
  #47
rootpooty
rootpooty's Avatar
Can someone please explain to me how backing this detent bolt out a little with a gasket/washer can ease putting the car in reverse? Im still learning about c5's thanks
Old 09-11-2011, 03:46 PM
  #48
MawneeC5
MawneeC5's Avatar
Wow I had forgoten about this mod. Did this on my 98 many years ago and it made a big difference. Ill have to remember to do this next time I have the Z in the air
Old 09-11-2011, 03:49 PM
  #49
Technite73
Technite73's Avatar
Who came up with this modification?
Originally Posted by Toque
Guys:
This modification will reduce the "notch" feeling when shifting between gears.
Easy to install and remove if you don't like it.
On my web site at the bottom:
http://ToqueZ06.com/
Anti-Venom 6 Speed Shifter Modification:
Toque
Old 09-11-2011, 04:44 PM
  #50
Toque
Toque's Avatar
I think it started in 2005 from Greg of AntiVenom inc in Florida (A Corvette/GM Tuner). Not sure though...
http://www.z06vette.com/forums/f5/an...ift-mod-84344/
http://www.z06vette.com/forums/f5/sh...-detent-86212/
http://forums.corvetteforum.com/c5-t...-shifting.html
http://forums.corvetteforum.com/c5-z...tly-is-it.html
Just something I read on here and other forums years and years ago.
I just thought I would bring it back to life for all the new-b's on here..
Toque
Old 09-11-2011, 05:44 PM
  #51
Zuti
Zuti's Avatar
Location: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Just did the mod today. I've got the Ripper on my car and I started with one washer, test rode and noticed an improvement, then, since it's so easy to change, tried two, and actually like the feel of 2 better. But my Ripper was really notchy and fairly hard shifting. I am also going to change to Amsoil and realign my shifter. This mod was a great improvement and I wish I'd done it a long time ago. Can't believe how easy it is. Once you find the detent, it is a 10 - 15 minute job start to finish, including getting in the ramps and jacking up the rear (assuming you don't have a lift). Thanks for bringing this mod back. Zuti
Old 09-11-2011, 06:33 PM
  #52
MawneeC5
MawneeC5's Avatar
Toque
Haha I thought that old thread seemed familiar. I remembered that big debate with boosted_Z06. Sure enough I have the last post in that thread.
Wait.....does that make me a thread killer?
Old 09-11-2011, 07:02 PM
  #53
Toque
Toque's Avatar
Hopefully not this time...
If you did, .... then hopefully this will keep it going...
Toque
Old 09-11-2011, 07:14 PM
  #54
MawneeC5
MawneeC5's Avatar
I hope not too. It really is a great mod. I drove my 98 around for two years after doing that mod and loved how easy it made quick shifting.
However, just because you CAN powershift 2-3 doesn't mean you should.....especially if boosted....my poor 10mm torque tube didn't survive for long
Old 09-12-2011, 04:56 PM
  #55
flynbyu2
flynbyu2's Avatar
St. Jude Donor '10
Originally Posted by flynbyu2
I purchased aluminum oil drain plug washers for 85¢ each. If anyone's having trouble finding these, I can send 'em out for $1 (ea) shipped.
Sent 2 out this morning and have 9 left.
Anyone else?
Old 09-12-2011, 05:14 PM
  #56
Chicago1
Chicago1's Avatar
Anyone else?
Not that I'm lazy to go to the store but I like when parts arrive in the mail. I will take two just pm a paypal addy. Thanks!!!
Old 09-12-2011, 06:26 PM
  #57
TriplBlk
TriplBlk's Avatar
No Chicago1, your pretty lazy
Jk man
To Anti-Venom 6 Speed Shifter Modification (Procedure)
Old 09-12-2011, 11:01 PM
  #58
MawneeC5
MawneeC5's Avatar
Modded my Z today. I just did about 1/16" this time around. Enough to make it smoother, but not enoguh to completely eleminate it. Its just right. Thanks again for reminding me of this mod!
Old 09-12-2011, 11:04 PM
  #59
Toque
Toque's Avatar
Glad it worked for you !
Toque
Old 09-13-2011, 08:19 AM
  #60
Chicago1
Chicago1's Avatar
Jk man
lol ok you got me!!! flynbyu2 is sending me two thanks man!!
Quick Reply: Anti-Venom 6 Speed Shifter Modification (Procedure)
