Anti-Venom 6 Speed Shifter Modification (Procedure)
#262
I installed two washers today, I guess my order was only for two washers and not 10. As many others have attested this made my shifter sillky smooth to shift into gear while remaining firm. Thanks for the suggestion, made a night and day difference with my mgw short shifter.
#263
#264
Pro Mechanic
#265
any one with a hurst shifter do this?
I just installed a RPM level 5 m12 and getting it into gear is a little firm for my liking (not side to side) shifting from 1 to 2 and so on
#266
Its easy and cheap to do, and easily reversible.
Toque
#268
Yeah I bought the 2 pack of washers but only put on one. I might try the second one the next time I already have my car lifted up for other work. Like you said, I've heard some say they used two washers and love it.
#277
Minor point and question: 3/4" is not 20mm, it is 19mm, so M20 3/4" is not strictly accurate. Anyone measured the inside diameter of the recommended washers? Or know what the actual thread is? Thanks.
#279
cant be leave I waited so long to get this done, my hurst short shifter was kind of a pain when putting around in traffic (when aggressive it rocks) installed one wash and its so much better i'd say i lost 40+ % of the notchy firm shifting feeling it still has some I might try one more just to see but i'm thinking it feel to loose
total time spent 20 minutes (15 was getting my tools out and packing them when i was done)
