Caliper painting - Duplicolor or G2?
I have been pricing this and I noticed that G2 is about 60% more expensive than Duplicolor. Can I please get some input from those of you who have used either of them? Do they still look good a year or 2 or 3 later?
How difficult is it to do?
How many calipers can you do with each kit?
Thanks a bunch!
Thanks a bunch!
Brush on Duplicolor still going strong after 5+ years
Did the calipers when changing front and rear pads. Unbolted calipers but left brake lines on so no bleeding required. Used all their brake clean and about another can and a brush and really cleaned off the crud before painting.
Did about 5 coats, one right after another with maybe 20 minutes dry time in between. One or 2 coats looks bad, 4 or 5 looks great. Finished remounting calipers and did a little touch up where I just nicked the paint.
Finished the CORVETTE logo with white paint. Still looks great. Got the red paint on my Sebring Silver C5 and looks like Z06 calipers.
Can't beat the price either. About $15. Have enough paint left to do whole job again. Go for it. BIGHANK
Oldtimer
Thanks a bunch!
Thanks a bunch!
I used duplicolor. Still looks fresh 2 years later. I also applied several coats. (3-4) I put chapstick on the Corvette letters, then scraped the paint off with a utility knife. Then sanded them with fine sandpaper to polish up the aluminum.
Received 19,427 Likes
'20-'21-'22-'23-'24
I used Folia Tech on my C5 - it's an epoxy based system and has held up very well.
I used Duplicolor on the brackets for my DD and have not been real pleased with it. It has not held up well and I have had to touch up a lot of areas since I first put it on. But, that's just my experience with it.
Received 1,680 Likes
I used VHT in a rattle can from AutoZone!
Mind if I hijack?
Think you got ur answer, so I guess I'll go ahead and hijack your thread. Anyone paint their calipers blue? I'm getting ready to try it (duplicolor), and would like to see some pics.
Although I have a Torch Red '97, I am tempted to try yellow of all colors. I would do the letters in red. I think a bold contrast would really pop.
Oldtimer
I like the yellow calipers w/ red body. Mine has red ones already.
I used duplicolor a few years ago. Painted the entire caliper then used sandpaper to sand the paint off the lettering so it looks like the z06 calipers.
Oldtimer
http://s434.photobucket.com/albums/q...947/For%20pub/
I block sanded the letters and painted with the duplicolor. Used a razor blade to take the paint off the lettering. It worked easier than I thought it would. Looks good too.
