Wheel Stripes on C6 ZO6 Wheels (Tutorial w/PICS)
So I put some wheel stripes on my black ZO6 reproduction wheels lately and I remember seeing some threads about people asking what they looked like. The main issue obviously is that the spokes go out to the edge of the wheel and the stripe doesn't have a completely flat area to adhere to. After doing it I think it looks fine and you can only see the distortion when viewing at an angle, not looking head on which is how you normally see the wheels. I have black wheels and I think the red does a great job of giving it that little bit of contrast between wheel and tire plus it matches the painted calipers too. I love subtle mods and always remember; the difference between ordinary and extraordinary is that little "extra".
Super easy mod to do, 100% reversible, and cheap... let's get started.
Materials:
Pinstripe tape: I went with 1/8th inch bought at O'riley's
Blade: for cuttin stuff
Denatured Alcohol: used to clean/prep wheel finish so stripe will stick
Adhesion Promoter: I used a promoter around the curved edges of the spoke to insure no lifting would occur
First I started by washing the wheels and tires, no brainer. After trying to stripe one wheel on the car I quickly decided to take them off the car and lay them flat on a work bench. You will have so much more control from that angle vs bending over and trying to get a consistent stripe around the vertical facing edge of a wheel on the car. It only takes a few minutes to do anyway.
Clean the outside of the wheel off with the denatured alcohol to remove and polishes, waxes, or sealants that may be on the wheel.
Next I used the edge of the promoter pad to apply a light swipe over the curved edges of the spokes. This will help the stripe stick much better. A word of caution though, don't get crazy and spread the promoter over everything, it can stain the paint a little bit and you will have to go over it with some polish to clean it up. No big deal but I just concentrated my application to where I really needed it, nowhere else.
Begin taping being sure to stay tight with the edge of the wheel. This is where the wheel being off the car comes into play.
When you make it around you want a little bit of overlap, then just trim off excess.
And done
Here is what the spokes look like from an angle. You can see it isn't quite perfect but it also doesn't really matter and when you are looking at them on the car you don't notice it as much.
Repeat for other wheels
Throw the wheels back on the car and enjoy the optical stimulus that is wheel stripes.
Thanks for looking. As always post up questions or comments if you have any. Mark
Materials:
And done
Received 1,681 Likes
Nice "How To"!
Received 19,546 Likes
'20-'21-'22-'23-'24
Nice job - the stripe looks very good on the wheels.
Thanks guys, the color is matte black and it is a vinyl wrap. I did it myself this past winter and there will be a tutorial/write up on that too in the next few days. Keep an eye out for it.
Planking on 18's
Planking on 18's
