Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-20-2011, 11:44 AM   #1
oneshot
CF Senior Member
oneshot's Avatar
Default Failed Inspection test - catalyst not ready
Hey Guys,
I have been battling problem for the sometime now. I have taken my car in to get inspected several times to different places and each time I fail my state inspection. Each time my report comes back with the Catalyst and Evap systems as not ready.
I found on the forum GM's "drive" cycle instructions and ran through those. Still no luck.
Someone said to take it to a dealer and have them do a reset on the computer. I have a custom dyno tune on the car and the programmer told me this would wipe out his tune. Now before you start think it is the tune. I have had the tune on the car for over 3yrs. This would be the 4th inspection I had with the tune on it. So me and the programmer who is Cory at Henderson Performance do not think it is the tune.
So does anyone have any suggestions? I thought about disconnecting the battery and let the car set for a hour so that everything will reset on the car. Does that sound like a good idea?
I really need your help I am 2x months out of inspection and with school starting on Tuesday there will be cops everywhere.
oneshot is offline   Reply With Quote
Old 08-20-2011, 12:40 PM   #2
01vetter
CF Senior Member
01vetter's Avatar
That doesn't sound right. You might want to post this in the Scan & Tune area. For some reason your computer isn't resetting after going through the ready cycle. I would suggest calling your tuner for suggestions.
I would check your battery, grounds and connections to the PCM. I am not an expert but if your PCM senses low or no voltage it will enter reset mode and you will get the "not ready" codes. I would disconnect the battery and try that. I think that you can read the codes from your dash readout so you can check for these codes before you go for an inspection. You may also have a problem with your PCM.
I hope this helps.
01vetter is offline   Reply With Quote
Old 08-20-2011, 12:45 PM   #3
Mr.Bill
We Miss You Frank...
St. Jude Donor '12-'13
Support Corvetteforum!
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
Send a message via ICQ to Mr.Bill
Check your gas cap and for vac leaks, Also pull your codes.
Mr.Bill is offline   Reply With Quote
Old 08-20-2011, 06:26 PM   #4
Aerovette
CF Senior Member
Aerovette's Avatar
I hope this helps.
Just to be sure you know...if you disconnect the battery you will need to do the drive cycle again. Also, the items on the drive cycle eventually all get covered in normal driving if you don't want to have to go through a specific routine and timeline.
Aerovette is offline   Reply With Quote
Old 08-20-2011, 08:06 PM   #5
nj02vette
CF Senior Member
nj02vette's Avatar
Location: Marlton. Increasing performance one speeding ticket at a time! NJ
If the catalyst system is showing up as "not ready", then it's probably the rear O2 sensors aren't reporting correctly, or they are reporting correctly and the cats are going.
Either way, since you have a tuner who is willing to work with you, just shut the codes off. Not a big deal at all.
nj02vette is offline   Reply With Quote
Old 08-20-2011, 08:15 PM   #6
87gtNOS
CF Senior Member
87gtNOS's Avatar
87gtNOS 87gtNOS
Quote:
Originally Posted by oneshot View Post
Hey Guys,
What is the procedure that gives this result? Do they plug into your ODB2 port? There is talk of that happening here in Ontario, Canada.
__________________
Why is he called '87gtNOS'?!
http://www.youtube.com/watch?v=yPNTkb6z074
87gtNOS is offline   Reply With Quote
Old 08-20-2011, 09:29 PM   #7
dougbfresh
CF Senior Member
Are you clearing ANY codes BEFORE you test?
dougbfresh is offline   Reply With Quote
Old 08-21-2011, 12:21 AM   #8
Camjamsdad
CF Senior Member
St. Jude Donor '13
Camjamsdad's Avatar
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicycle.
When I lived in Texas they only emission tested in the major metro areas. How about a drive to podunk county that doesn't test? Back in the day you could just buy the sticker and slap it on the windshield yourself but the trick was finding the right shop.
Camjamsdad is offline   Reply With Quote
Old 08-21-2011, 08:59 AM   #9
dougbfresh
CF Senior Member
These are NOT codes, they are I/M monitor tests-they can not be tuned out. If it's like IL-the just plug into the OBD port. I have other OBD readers, I plug in all my vehicles before I go to test-I know 100% that all the I/M monitors pass before I go in.
The I/M monitors test things like Catalyst, EGR (where applicable), Evaporative Emissions,... Some states will allow you to fail 1 I/M test some will not.
Here in IL, the OBD test goes right to the State-no way to get around it.
Old 08-21-2011, 09:53 AM   #10
carhodge
CF Senior Member
carhodge's Avatar
Move to okla no inspection.Just kidding,that sucks.
carhodge is offline   Reply With Quote
Old 08-21-2011, 12:28 PM   #11
oneshot
CF Senior Member
oneshot's Avatar
Correct, the inspection places just plug into the OBD port and read the monitors. I am not sure if they will allow it to pass with 1 failed IM test or not.
Old 08-21-2011, 12:32 PM   #12
oneshot
CF Senior Member
oneshot's Avatar
Is there a way I can have the rear O2 sensors tested? Would the OBDII readers being able to test if the rear senors are working or not?
Old 08-21-2011, 03:10 PM   #13
Aerovette
CF Senior Member
Aerovette's Avatar
If I remember correctly Texas allows 1 fail but cannot pass a "not ready". I had some repairs done and the shop disconnected the battery. It caused me to fail my inspection. I had to drive for about a week with my fingers crossed until I could get the drive cycle completed.
Old 08-21-2011, 03:29 PM   #14
sfc rick
CF Senior Member
sfc rick's Avatar
OMG!!!! I'm in Angelina County and we don't have that silliness! Tires-Check! Lights working-Check! Wipers-Check! Brakes-Check! $14.50-Check! Here's your Inspection sticker Have a nice day!
sfc rick is offline   Reply With Quote
Old 08-21-2011, 11:01 PM   #15
oneshot
CF Senior Member
oneshot's Avatar
I wish I could take it to a different county however I live just north of Austin (Williamson County) and we are required to have that whole stupid emission test done. If I try to go to a different county they are required to run the same test that Williamson County would run. SO it is pointless to go some where else.
I changed out the o2 sensors downstream today and I bought a OBD2 scanner tool so I can monitor the I/M test status. I do not have any DTC codes current or history on the car. So now I will drive it and see what comes back.
I am thinking my next steps are going to be to replace the catalyst's but that does not help we with the Evap system.
Does anyone know what the EVAP system is and what makes it up?
Old 08-21-2011, 11:13 PM   #16
shadowman1
CF Senior Member
shadowman1's Avatar
In Texas you can have 1 moniter " Not Ready " and pass but none can be " Failed ". Any failure will turn on a check engine light.
shadowman1 is offline   Reply With Quote
Old 08-21-2011, 11:15 PM   #17
shadowman1
CF Senior Member
shadowman1's Avatar
Evap system stores gas vapors in a charcoal canister and at certian times a solenoid opens to burn them thru the engine to help reduce pollution.
If you get down to only 1 " Not Ready" you will pass in Williamson county.
Old 08-22-2011, 10:48 PM   #18
dougbfresh
CF Senior Member
If your not getting any EVAP codes, the I/M test will eventually run on it's own and pass or fail. You'll see this on your scanner. If it FAILS, it will set a code (i.e. the loose gas cap will set this code).
Old 08-22-2011, 11:11 PM   #19
oneshot
CF Senior Member
oneshot's Avatar
I found the line between the Evap solenoid and the TB was not all the in. So I am hoping that fixes the Evap "not ready" but I have to drive around for a while to burn off some gas. What I have read is that the Evap test will not run until the gas tank is less then half full.
Old 08-22-2011, 11:11 PM   #20
andy46
CF Senior Member
andy46's Avatar
Quote:
The testing has been here in BC for years now, newer cars are simple, they just plug into the OBD port, if you have no issues you won't have a problem.
The whole crap is nothing but a money grab, costs $45. here every year!!
andy46 is offline   Reply With Quote
Reload this Page Failed Inspection test - catalyst not ready
Tags
2002, c5, catalyst, complete, corvette, e5, evap, fails, fbody, gmc, inspection, mon, ready, texas, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
