Introducing VetteNuts VetteBins and Partitions
Supporting Vendor
St. Jude Donor '11
VetteNuts VetteBins and Partition Combo For your C5!
These are hand made from 1/2" MDF and weigh in at 20lbs for both. We take great pride in producing a high quality product with attention to detail.
These come standard with Push to open Lock/Latches with keys!
There are lots of options to choose from to customize these any way you want them.We offer *LED lighting for the storage compartments so you can see whats inside in low lighting conditions and it adds a custom look. These come on when the door is opened and are off when the door is closed. Also the Gas Struts are a great option so the door stays open when storing your personal items.
The Center Storage Tray is another option for easy/quick storage. We also offer *LED Lighting for this, we provide instructions and wiring on how to make this light come on/off when the car doors/hatch are opened!
* LED Lighting in various colors.
These will work with Coupes, Z06's and Convertibles.
For Coupe owners you can store your targa top with no issues!
Z06 Version
Coupe: Interior dimensions for each compartment are 9.75" x 20" x 2'. If ordered without a center divider it would be 40.75"
Z06: Interior dimensions for each compartment are 15.5" x 20" x 2"
Convertible: 14" x 20" x 2
Starting at $195!Z06: Interior dimensions for each compartment are 15.5" x 20" x 2"
Z06 Version
We can customize these to accommodate amps or even add tv screens in the partition!
Here is one with a custom logo option.
That is real nice and looks quality made - any for Coupes?
Thanks,Matt
Thanks,Matt
Supporting Vendor
St. Jude Donor '11
We are finishing one for my dad's vert this weekend so i will have some soon.
You list the interior dimensions of each bin for the Z06 & Coupe. Which applies to the convertible, or are they different?
If ordered without the center tray, does it come with just one big door, or are there still two?
Thanks, and sorry you can't make Carlisle.
Supporting Vendor
St. Jude Donor '11
Convertible sizes added. 14" x 20"x 2" The Vert Edition will still come with two doors. We can do pretty much anything you want so if you have other ideas in mind we can produce it.
OK, can you tell me the distance from the center of one lock to the outside edge, left or right? I'm trying to see where the lock ends up in relation to the seat back, and in my case, the seat hoops.
Also, how about an option for ***** instead of locks? All I need is another set of keys to lose...
Supporting Vendor
St. Jude Donor '11
My vendor only offers latches with locks. If you never lock it you will not need the keys.
After rereading your specs I see that the lock is a push-in and turn, so I don't have to use the keys.
Supporting Vendor
St. Jude Donor '11
Actually, I am looking for the distance from the lock to the very outside edge of the complete unit, not just the bin door. This will tell me where the lock falls in relation to my seat hoop. I want to see if I'll be able to reach thru the hoop to open a bin. If the lock is centered within the hoop it'll just make it easier to reach, that's all.
Supporting Vendor
St. Jude Donor '11
Ok here are the pics of the new design for the convertibles. We are going to incorporate a separate open storage bin in the rear of it. We can leave it as one large bin or divide it into two. What do you guys and girls think? It will all be carpeted.
Here is another idea. We could reverse the open bin to the front and the doors to the rear. Opinions?
OK, this shows me that the latches are centered pretty much with the seat backs, which is good.
Now, I already have a partition that slants towards the front and under the top when stowed, whereas your partition goes straight down. So, the extra tray behind your bins won't work for anyone with a similar partition as mine.
If you consider making a "trunkated" version for the convertible owner who has a partition style similar to mine, I've come up with some dimensions that will work for us.
The 11" depth is what is available to the point where our slanted partition starts. Another critical dimension is the 7" depth to the back of the bin door, where the hinge is. This allows the bins to open with the top stowed, as you undoubtedly already know. The other dimensions can vary.
Another idea just occurred to me. Instead of making one big 19" unit for the convertibles (which won't work for some of us), why not make an 11" AND an 8"? That way everyone's "covered".
I was thinking about adding something like this to me 04 coupe but the top half of the partition was going to be made of Plexiglas so that I could still see out the back. Got anything that seals off the trunk area in a coupe?
Supporting Vendor
St. Jude Donor '11
Received 19,407 Likes
'20-'21-'22-'23-'24
Great looking product.
