ABS, Traction Control error message
Old 07-10-2011, 11:08 AM
HowardsRed01
3rd Gear
HowardsRed01's Avatar
Default ABS, Traction Control error message
I've had our stock 01 for 2 years and the above sensor came on a couple times during the first few months and then I changed a couple grounds and it quit until a month ago, now it's on every time I start the car. I can press reset until the warnings disappear but the warning lights stay on...Any suggestions?
Howard
Old 07-10-2011, 11:15 AM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Howard
Grab the Codes from the DIC and let us know which they are - that will point us in the right direction!
Do-It-Yourself owners will be most interested in the display of diagnostic trouble codes for all modules that transmit them. The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
http://www.c5help.com/c5_dtc_codes.htm
Thanks,Matt
Old 07-10-2011, 11:23 AM
DeeGee
DeeGee's Avatar
Thanks,Matt
There are a number of elements to the system and only the codes will tell which is the problem
Post them up. There are quite a few AH/TCS experts on the Forum.
Old 07-10-2011, 11:33 AM
HowardsRed01
3rd Gear
Codes I retrieved are:
28-TCS C 1214 HC
60-IPC U 1160 H
AL-RDCM B 2265 H
Old 07-10-2011, 11:40 AM
madmatt9471
28-TCS C 1214 HC
60-IPC U 1160 H
AL-RDCM B 2265 H
Don't worry about the other ones just the TCS:
C1217 BPMV Pump Motor Relay Contact CKT Open
You want to go to the connection on the ABS Pump/Module pull the Harness Clip off and clean the contacts with contact cleaner "NOT WD-40" or any oil based spray! A CONTACT Cleaner!!!
Inspect the pins and sockets (Male and Female connections within the clip itself) make sure none are out of round or appear to not be making a clean connection) repair if they are with a dental pick set!
Re-Clip it in and make sure it is and clipped tight, locked down with the factory clip. Give it a test drive!
We will go from there if it comes back this is STEP #1
Thanks,Matt
Old 07-10-2011, 11:42 AM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Sounds like maybe your ABS module is in need of repair.
I had mine fixed by ABSFIXER and it works great, I had the 1214 code also.
Mr.Bill
http://www.absfixer.com/
madmatt9471
Also go under the hood in the fuse box, battery den area and check the the RELAY (ABS Relay) -
Pull it out clean the tabs and inspect the female socket with flashlight! Use contact cleaner!
We'll go from here!
Thanks,Matt
Old 07-10-2011, 11:46 AM
Mr.Bill
Mr.Bill's Avatar
Thanks,Matt
He is getting the 1214 C, Not the 1217 code.
Old 07-10-2011, 11:50 AM
HowardsRed01
3rd Gear
Thanks,Matt
Codes are: 28-TCS C 1214 HC, 60-IPC U 1160 H and AL-RDCM B 2265 H
Old 07-10-2011, 11:54 AM
DeeGee
DeeGee's Avatar
I'm afraid a C1214 (C meaning current) is a classic EBCM failure. You can replace it or send it to absfixer.com. the repair cost with those guys is about $150 against $1000+ for a new EBCM.
There's a DIY thread on how to resolder the EBCM circuit boards if you're handy that way (and brave!)
The good news is you can drive the car while the EBCM is away for fixing, you just lose the protection from AH/TCS and ABS while its not fitted.
Let me know if you want the procedure telling how to pull the EBCM.
Old 07-10-2011, 11:56 AM
Mr.Bill
Mr.Bill's Avatar
The codes with the "H" after them are History codes and are no longer current, The codes with the "C" are current and are the ones that need attention.
Mr.Bill
Old 07-10-2011, 01:29 PM
madmatt9471
OOPS my wrong - still go through the same procedure and check all the connections -
"IF" it does not work then your Model Module can be sent to ABS Fixer like Mr.Billl said!
Thanks,Matt
Old 07-10-2011, 06:25 PM
02koolC5
02koolC5's Avatar
ah the old 1214 code you can send it in or fix yourself, wasn't that hard to do, when removed from car its safe to drive, but your steering will feel heavy and sluggish, brakes also, just a little heads up on that.
here's the DIY thread post number 111. digikey.com also sells the relays for $1.78 good luck and hope that helps
http://forums.corvetteforum.com/c5-t...iy-thread.html
Old 07-14-2011, 09:25 AM
All_Motor_C5LS6
All_Motor_C5LS6's Avatar
Thanks,Matt
Where is the ABS module located?
Old 07-14-2011, 12:08 PM
rboineau
rboineau's Avatar
If you or a friend are comfortable with delicate soldering on circuit boards your 1214 code can probably be dealt with yourself. As the other posters have said, it is (normally--not always) a relay in the EBCM. You may not even need a new relay, as quite a few people have found the problem to be poor/broken solder joints on the relay and once re-soldered it is fine. Some replace anyway, of course, as the relay is cheap as mentioned. Good luck and please post back after you have solved your problem telling us what you did.
ABS Fixer is not the only game in town if you don't want to tackle it yourself. Ebay has at least one repairman who has done work for some Forum members and I haven't heard complaints. The eBay guy is also much cheaper. Don't have his name but a search on the Forum may put you on him, or ask.
Old 07-14-2011, 12:49 PM
nvusgt
nvusgt's Avatar
http://forums.corvetteforum.com/c5-t...r-fleabay.html
That is a step by step for EVERYTHING. From removal of EBCM to fixing the relay issue and re-installing. Take a look through it and see if you're comfortable with the procedures. If you are tackle it be done with it and save a decent chunck of change. I've done this, made the write up and numerous others have followed....it works.
Old 07-15-2011, 12:32 PM
madmatt9471
1997 - 1998 Mid year they are located in the rear of the Vette but inlate 1998 they stareted to install the ABS unit up front, right in front of the Power Steering Pump, (Drivers Side)
Thanks,Matt
To ABS, Traction Control error message
Old 07-21-2011, 07:26 PM
Oldvetter
Oldvetter's Avatar
My ABS and Traction warning lights were lite for about 3 days on my 1998. I noticed the battery was not fully charged (reading about 12.4 volts). I charged the battery AND removed the 2 fuses (I did not see any relays on my 1998) and cleaned the contacts/fuses. It fixed this, no more lights !
Old 03-04-2012, 03:42 PM
Screamer
Screamer's Avatar
Default Error 1217 FIX
I had this problem with Service Traction control light being on and the abs. I cleared all my codes and the 1217 c keep popping back up.
I check the fuse box near the battery under hood. The #52 ABS Fuse 40 amp was blown (probably from changing the battery or from my old battery constantly loosing charge after Vette sat for periods of time) I replaced the huge fuse and everything is fine. Remember after you change fuse to clear the error code in computer.
Hope this helps someone out :-)
Old 03-04-2012, 03:58 PM
guido7834
guido7834's Avatar
I also get the service abs/traction contriol warning on occasion, but only when I pull out of my garage and make a hard turn onto the drive way. Does the steering position have anything to do with this?
Quick Reply: ABS, Traction Control error message
