Need help from someone with a shop manual: Water pump
Old 06-23-2012, 01:11 PM
SFL_driver
SFL_driver's Avatar
Default Need help from someone with a shop manual: Water pump
I'm in the middle of the water pump install and I need to know what ft-lb to torque the 6 longs bolts to (3 on each opening of the block)?
I'm concerned about over torquing the bolts and stripping the threads in the aluminum block.
Also should I use blue locktite on the bolts?
Old 06-23-2012, 02:26 PM
Triton170
Triton170's Avatar
2000 shop manual says the same thing - 11ft-lbs the first pass and 22ft-lbs the second pass.
No to the locktite.
Old 06-23-2012, 02:39 PM
Daddyrama31
Daddyrama31's Avatar
No to the locktite.
Old 06-23-2012, 02:51 PM
Sonny71
Support Corvetteforum!
Sonny71's Avatar
Oldtimer
2003 shop manual says the same thing
Old 06-23-2012, 05:55 PM
Fast one
Fast one's Avatar
http://www.c5help.com/C5_Torque_Values.pdf
I copied this double sided then laminated it; use it all the time because it's faster than the shop manual.
Old 06-24-2012, 12:31 AM
SFL_driver
SFL_driver's Avatar
Wow thanks for all the replys! I was able to finish the job a few hours ago just before it got dark.
Oh and that document with the torques is awesome! I'm printing it out tomorrow morning!
To Need help from someone with a shop manual: Water pump
Quick Reply: Need help from someone with a shop manual: Water pump
