Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-07-2011, 09:24 AM   #1
fastone88
Junior Member
Default Door Lock Problems - Actuator or Relay?
I have a 1998 Corvette. The passenger side door lock locks properly, but does not unlock when using the fob or pressing the door button. I am guessing that I need to replace the door lock actuator, but reading the forum it seems that relays are a common problem. I do not hear the faint clicking noise that others are describing with relay problems, so I still think it might be the actuator. The door locks every time, but it does not unlock. What do you guys think? Is it a bad actuator or bad relay? Thanks for your help. I have to remove the door panel to fix a floppy mirror problem, so now is the time to fix the door lock.
fastone88 is offline   Reply With Quote
Old 07-07-2011, 10:30 AM   #2
DeeGee
DeeGee's Avatar
Dave Gledhill David Gledhill
The relay is most common. A dealer would just replace the whole module but Bakersfield's thread is the best How To out there.
__________________
http://deegee-media.webnode.com/
2002 A4 Convertible, Mag Red II
Euro head and tail lights, Z06 screens, frame savers and rocker rails, Pioneer AVIC X1R nav/DVD player, EE catch can.
Tattershall Castle, England *** **** **** *** Las Vegas, NV
Jet Noise, the sound of freedom!
DeeGee is offline   Reply With Quote
Old 07-07-2011, 11:59 AM   #3
RetiredSFC 97
CF Senior Member
St. Jude Donor '09-'10
RetiredSFC 97's Avatar
I have to ask.
Are you presssing the unlock button twice? Also insert your key into the drivers door and unlock it, then turn the key again to unlock the pass door. If it won't unlock in either of these two ways it's something with your door switch. IMO
Someone else may have your answer on that.
Edit I see now it doesn't unlock when pressing the unlock button inside either. Sorry for wasting your time!
RetiredSFC 97 is online now   Reply With Quote
Old 07-07-2011, 10:22 PM   #4
02koolC5
CF Senior Member
Support Corvetteforum!
02koolC5's Avatar
You could swap the modules, if it doesn't work then it could be actuator....
__________________
2002 Black Coupe
LS1 A4 2:73
Fixes: Headlight gears,Passenger door lock relay, Multifunction lever and EBCM relay fix
Sac City Fangs, Sequential Tails, Hankook V12 EVO,C6 Z06 shocks
Callaway Honker, Billy Boat PRT/Speedway Tips
Save the wave!
02koolC5 is offline   Reply With Quote
Old 07-09-2011, 02:04 PM   #5
fastone88
Junior Member
Default Going to try to replace middle relay
DeeGee,
I think I will try to replace the relay myself. I am guessing the the middle relay that unlocks is bad. The lock does unlock sometimes (maybe once every 30 times the button is pushed). Do you happen to have a copy of Bakerfield's post?
02KoolC5,
Trying to use the driver's door module to test the passenger side door module is a great idea. However, I don't want to remove the driver's door panel unless I have to.
Does anyone know a good place to buy door lock relays? Are the quality of some relays better than others?
Old 07-09-2011, 02:25 PM   #6
Chris Stewart
CF Senior Member
Chris Stewart's Avatar
I got the JSM1-12V-5 from digi-key. Ordered 5 and only have 2 left. These are good to have around.
Chris Stewart is offline   Reply With Quote
Old 07-09-2011, 04:28 PM   #7
DeeGee
DeeGee's Avatar
Quote:
Originally Posted by fastone88 View Post
DeeGee,
PM me with your e mail and I'll send it on
Old 07-09-2011, 08:10 PM   #8
fastone88
Junior Member
Default Relays ordered
Thanks Chris. I just ordered 5 relays.
Old 07-09-2011, 08:17 PM   #9
02koolC5
CF Senior Member
02koolC5's Avatar
yea I didn't do the swap myself for that reason but thought I'd throw it out there here is the how to I used and the vetteessentials.com for panel removeal good luck
http://www.ronjpics.com/Corvettestuff.htm
I think quality is about the same I also got mine from digikey
Old 07-10-2011, 02:00 AM   #10
DeeGee
DeeGee's Avatar
Quote:
Thanks for the reference # Chris. My door lock module is starting to go bad again. I checked and I found a supplier for that relay here in England. Looks like I have a job to do.
Old 07-25-2011, 12:28 PM   #11
fastone88
Junior Member
Default Update - Problem Fixed!
I was able to remove the old relay and solder a new one onto the circuit board. The unlock relay is the middle one, and I had a heck of a time getting it out. I was using a 15 watt soldering iron, but bought a 40 watt one to get more heat. I have very little soldering/desoldering experience, so I watched I few youtube videos on the subject. I finally got the relay removed, and soldering the new one on was a little easier. I still had trouble getting the solder out of the holes of the circuit board so that I could install the new one. I tried using the copper ribbon and a vacuum tool, but that solder was still hard to remove. I ended up heating each area and pushing the relay to get it installed. Once in position, I soldered each of the five pins.
I plugged the repaired door module back in, and the unlock button now works! It was a bad relay after all. Thanks for all the advice I got on the forum! This saved me a lot of money. I would rather pay $1.67 for a relay than buy an entire door module or replace a perfectly good door lock actuator. If I can do this repair, anyone could!
Old 07-25-2011, 12:59 PM   #12
DeeGee
DeeGee's Avatar
Great job
My turn next. I have the relays ready to go.
Old 11-27-2011, 08:28 PM   #13
goober51
CF Senior Member
Quote:
Originally Posted by DeeGee View Post
Great job
Just curious..how did that relay replacement work out for u dee gee? I have the same problem now..thks
goober51 is offline   Reply With Quote
Old 11-27-2011, 08:35 PM   #14
goober51
CF Senior Member
ok; I'll tk your word for it. I am going to try it..mine just went bad the other day..
Old 11-28-2011, 03:34 AM   #15
DeeGee
DeeGee's Avatar
Quote:
I've been practicing my soldering skills
It hasn't reached the top of the Honeydoo List yet
A friend here in UK also has the problem so he's going to help out when we get round to it. I have another friend who's an electronics guru so I may invite him along too and make it a door module party.
Old 02-07-2014, 02:52 AM   #16
Macleod52
CF Senior Member
Macleod52's Avatar
Can the same relay be used for the door locks and windows? I thought they were the same but in one of the threads it looks like they are different part numbers.
Macleod52 is offline   Reply With Quote
Old 02-07-2014, 07:10 AM   #17
goober51
CF Senior Member
Quote:
I thought they were the same. I thought i read that somewhere when i dealt with this prob.
Old 02-07-2014, 09:51 AM   #18
92GA
CF Senior Member
Oldtimer
92GA's Avatar
I just had one of the electronic techs at work replace the relays in one of mine. There were 4 relays with 3 different part numbers. I bought them from digi-key last year. You have to open up the module to get the part numbers unless somebody on here has those numbers.
92GA is offline   Reply With Quote
Old 02-07-2014, 12:48 PM   #19
Cubman
CF Senior Member
Cubman's Avatar
Mine was the unlock relay( JSM1-12V-5 ), $1.50 at digkey as stated above.
Cubman is offline   Reply With Quote
Old 02-15-2014, 03:20 PM   #20
Southerncol
Junior Member
Default Actuator or Relay
My driver side door panel lock/unlock buttons will open the door locks, however, to lock the doors (pushing the buttons to lock), nothing.....this been going on for a month...I do not have a FOB, so upon exit I usually hit the "lock" button, hear the actuator, and it use to work....not anymore....
I bought a LCDM off E Bay, $45, rather than spend $80 for all the soldering stuff needed, just installed it, and it did not fix the problem....
Now, if an actuator goes bad, can it still work to open the lock and not function to close or lock the door?....The passenger sides door control work for both (locks and unlocks) so that tells me my actuator is ok, correct?....Now, could there be a wire going bad?...Could I have two bad relays, my box and the new/used box too?...Damn
Southerncol is offline   Reply With Quote
Reload this Page Door Lock Problems - Actuator or Relay?
Tags
2009, actuator, c5, c6, corvette, covette, door, drive, driver, lock, malfunctions, module, relay, relays, unlock
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
