Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-27-2011, 12:14 AM   #1
Got uid0
CF Senior Member
Got uid0's Avatar
Default DIY Paint Side skirts and front splitter
Materials needed
Dawn dish soap or degrease product
2 cans Rust-Oleum truck bed coating
3 cans Rust-Oleum Primer 2 in 1 FIller & Sandable
4 cans Rust-Oleum Univeral All-Surface Flat Black
150 Grit Sand Paper
400 Grit Wet sand paper
600 Grit Wet sand paper
scotch bright pads
(heavy duty, finishing pad, red scotch bright sponge)
Tack Cloth
Step 1: Wash the fiberglass down to remove wax from the mold using Dawn dish soap or degrease product.
Step 2:
I chose to coat the underside of the fiber glass side skirts and front splitter with truck bed coating. This gave the fiberglass a finished look and possibly increased the strength.
Fiber Glass unfinished back side
Click the image to open in full size.
Fiber GLass Finished with Truck Bed Coating
Step 3: Scuff the Gel Coat with 150 grit sand paper
You may choose to bypass adding primer and simply scuff the gelcoat and proceed with painting.
Step 4: Add Primer
Step 5: Sanding
Use Scotch Bright pads to remove loose primer from pieces.
Use scotch bright sponge to assist with wet sanding
Wet area to be worked and gently sand using 400 then 600 grit wet/dry sand paper
Step 6: Paint
Use Tack cloth to remove any particles from your surface before painting. You may find a static charge is present from sanding with the scotch bright pads. I used a dryer sheet to remove the static build up before painting.
Picture of painted side skirts next to gel coated front splitter
The pieces came with self tapping screws.
You will need to remove a screw at the rear and at the front of the underside of the vette.
I found that the screws are too short to go through the new material and keep the existing body panels in place.
The side skirts have indents showing where to drill the screws into the side of the lower body panel.
I chose not to drill into the side of the body panel and instead use 3M double sided tape along with drilling into the underside of the body/frame with self tapping screws.
Before Install
After Install
Installed mini Spoiler
Install pics of the front splitter in the near future.
Got uid0 is offline   Reply With Quote
Old 06-27-2011, 12:29 AM   #2
glorysends
CF Senior Member
Support Corvetteforum!
glorysends's Avatar
Matt Burris MattBurrisATD
Send a message via AIM to glorysends
Looks awesome!
glorysends is offline   Reply With Quote
Old 06-27-2011, 12:51 AM   #3
JuicedZ
CF Senior Member
JuicedZ's Avatar
chris.duperre chrisduperre Duperre BlackZ28 Red350GT mrduperre
Send a message via ICQ to JuicedZ Send a message via AIM to JuicedZ Send a message via MSN to JuicedZ Send a message via Yahoo to JuicedZ Send a message via Skype™ to JuicedZ
looks great! what kind of side skirts are those? Where did you purchase them?
JuicedZ is offline   Reply With Quote
Old 06-27-2011, 01:30 AM   #4
yaknow
CF Senior Member
yaknow's Avatar
nice job, like the idea of spraying the truck bed liner on the underside.
yaknow is offline   Reply With Quote
Old 06-27-2011, 07:31 AM   #5
4SFED Z
CF Senior Member
4SFED Z's Avatar
I like it. However, one suggestion. If you are going for the flat look, I wouldve sprayed it with some flat clear for protection.
Side note....congrats on tackling the job yourself
4SFED Z is offline   Reply With Quote
Old 06-27-2011, 08:15 AM   #6
JW@JWMotoring.com
Supporting Vendor
St. Jude Donor '09-'10-'11-'12-'13-'14
JW@JWMotoring.com's Avatar
jmotoring jwmotoring C5ish
Not sure if that's ours or not, but good job on it
JW@JWMotoring.com is offline   Reply With Quote
Old 06-27-2011, 09:10 AM   #7
rdline
CF Senior Member
rdline's Avatar
rdline is offline   Reply With Quote
Old 06-27-2011, 09:12 AM   #8
jrose7004
CF Senior Member
jrose7004's Avatar
Jim Rose Jim Rhttp://www.linkedin.com/profile/view?id=89789687&trk=hb_tab_pro_topose
Good job!
jrose7004 is offline   Reply With Quote
Old 06-27-2011, 11:07 AM   #9
Got uid0
CF Senior Member
Got uid0's Avatar
Purchased from bodykitman before JW carried it, so if you are interested hit up JW one of the better forum vendors!
Old 06-27-2011, 11:40 AM   #10
$$$frumnuttin'
$$$frumnuttin''s Avatar
Location: Less than 1 month to go to hit the 15 year mark.
jerry carguy jerry carguy
nice...good idea not to use the molded in locations for the tapping screws....the odds of those holes hitting their mark are higher than winning the lottery!!
$$$frumnuttin' is offline   Reply With Quote
Old 06-27-2011, 06:32 PM   #11
jsherm
CF Senior Member
jsherm's Avatar
Send a message via AIM to jsherm Send a message via Skype™ to jsherm
Seen all these plasti dip threads. Thought about painting my side skirts black on my red vert. It's always dirty there anyway from DD road grime ...
jsherm is offline   Reply With Quote
Old 06-27-2011, 06:36 PM   #12
JW@JWMotoring.com
Supporting Vendor
Quote:
One of our customers did this to his front splitter he got from us
Click the image to open in full size.[/quote]
Old 06-27-2011, 10:28 PM   #13
TIKTGTR
CF Senior Member
TIKTGTR's Avatar
Man....that turned out really nice. I want to do that set up so bad but my car is in the weeds and my driveway would really love that front piece Turned out great man
TIKTGTR is offline   Reply With Quote
Old 06-28-2011, 11:50 PM   #14
Got uid0
CF Senior Member
Got uid0's Avatar
order a set if you like the look
http://shop.jwmotoring.com/product.s...&categoryId=38
Old 06-29-2011, 12:34 AM   #15
corvettedaddy11
CF Senior Member
corvettedaddy11's Avatar
corvettedaddy11 is offline   Reply With Quote
Old 06-29-2011, 12:39 AM   #16
Johnson 92
CF Senior Member
C5 of the Month 6/13
Johnson 92's Avatar
OKCFan32
Looks good!!
Johnson 92 is offline   Reply With Quote
Old 06-29-2011, 02:45 PM   #17
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
You did a great job and the new pieces look fantastic on the car.
Vetteman Jack is offline   Reply With Quote
Old 06-29-2011, 03:02 PM   #18
Rob04C5LM
CF Senior Member
Rob04C5LM's Avatar
Good job on the DIY
It came out great - I love the white/black contrast between the body and the aero pieces
Rob04C5LM is offline   Reply With Quote
Old 07-03-2011, 06:48 AM   #19
Tuxblacray
CF Senior Member
Tuxblacray's Avatar
Send a message via AIM to Tuxblacray Send a message via Yahoo to Tuxblacray
Looks hauntingly familiar too me... Nice Job! Keep up the good work...
Tuxblacray is offline   Reply With Quote
Old 07-03-2011, 01:28 PM   #20
Shirl
CF Senior Member
Shirl's Avatar
Nice job! Looks great!!
Shirl is offline   Reply With Quote
Reload this Page DIY Paint Side skirts and front splitter
Tags
c5, coat, corvette, diy, fiberglass, front, gel, paint, painting, sanding, side, skirt, skirts, splitter, white
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
