Best low profile / racing jack?
I am looking for recommendations on low profile racing jacks for the C5. My car is lowered with rocker rails.
I have had two Sears aluminum low profile racing jacks which have failed over the past 6 years. I don't want to spend top dollar but I am looking for something to last more than a few years. Especially since it is only used for maintenance work. I am almost at a point were I will no longer by anything other than life-time warrantied hand tools from Sears.
I have two old school jacks that have sat out in the garage for the past 10 - 20 years which still work to this day. Go figure...
Appreciate the recommendations!
Received 1,762 Likes
I haven't really found any low profile jacks I was happy with. I made some really solid ramps out of 2X10's that'll get my car far enough off the ground to get a normal floor jack under it...
Thanks. I have some ramps that I made too that I use as well. I tend to use those when I want to get the whole car evenly off the ground. I still would like to have the jack as it can be used very quickly without repositioning my car.
Received 2,688 Likes
2018 C5 of Year Finalist
I sure hope these jack failures didn't occur when the car was up!
I have a low profile jack I purchased at Advanced Auto and it has worked well in a very limited capacity. I just don't want to jack up the car using the side pucks during my next wheel/tire change only to have the jack fail while engaged.
The ATD-7325 (same one as the Omega 29023, just under a different badge) is very well regarded here. Amazon was selling it for $248.83, but now it goes for $299.95. You can see it here.
It's been discussed in depth here.
What really separate this one from the pack, besides its extremely low profile, is its length. It allows you to reach the front and rear crossmembers from the front and rear end of the car respectively, in order to raise the whole axle.
American Forge & Foundry Model 200T. It is not aluminum, weighs just under 100lbs, very low profile, have had mine for 2 years...great jack, has padded lift plate, check it out ($250ish). If you want something portable and inexpensive then check out Harbor Freight, they have a whole selection and you can get a decent one for about $59-$79. Most jacks are now made in China with a select few still made in the US but those will cost above $400.
I just bought the $69.00 Harbor Freight 1.5 ton low profile aluminum race jack. I have used it about five times. For the money it could give out in a year or two and I'll just put it with the rest of my scrap metal and take it to the salvage yard. Collecting scrap metal has become my second hobby. I cringe at the cash I have trown away in the past. Keep it seperate stock pile it then PAYDAY!!!
NAPA has a nice 2 1/2 ton low profile jack that works great, we use this one at the race shop, it is not aluminum so it is a little on the heavy side. We keep a sears aluminum in the trailer but hardly ever use it since the car has air jacks on it.
i got one off the auction site, I been through 2 sears "racing jacks" also. they both retired soon after the 1yr warranty. it was made by a company name Daisy. and it goes from 4"-18" low enough to slide under my lowered car.
I have the previous version of this jack:
http://www.harborfreight.com/automot...ack-68050.html
The new one has the rapid pump feature, and the jack is a bit thinner, but both have a super low starting height of 2 5/8"!
Works great for me, but I still drive onto 2x12s on my stock height Z06 so I can avoid the plastic airdam.
This is what I use, dont use it much so it will probably last a while. Seems to work very well.
Purchased from Autozone in TX:
Torin Aluminium Low Profile Racing Jack
Same here. It was like $59.99 with the coupon out of Motor Trend. Rapid pump, very low profile (under 3"; fits under my C5 that is lowered using Zip lowering kit with room to spare). Love it!
I hve an arcan x35. About $100. Fits under the car at the lowest point and lifts something like 19"
It's hefty, (80lbs I think) but not too hefty that the average guy can't easily carry it. If you have arthritis or a disability though, it could easily be too much.
Have heard nothing good about Sears jacks, although I have their 3 ton high lift jack stands and will recommend them to everyone they are great for $25 a pair.
I was going to buy their low profile aluminum racing jack then saw that one and decided to wait for some feedback before I bought it. Looks like a great jack for the money and I'm sure it'll eventually go on sale in the $70 range.
Thanks!
