clear coat issue
there are a few articles on google, but nothing explains it clearly. this guy has taken a lot of classes for automotive painting, but he said most of the things he knows, they don't teach you in any class.
i really dont see why this is a difficult concept to understand. if you heat up any kind of polymer, it is going to be easier to form.
im not stating this as fact or anything, just that i was told this by a professional.
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
Way to go guys...all this ranting probably confused the OP and now he's going to take a torch to his car to "heat" up the paint OR sand it down to where it's evenly scratched everywhere.
I do paint work. DO NOT buff the clear till it is hot!!!! we sometimes pin stripe brush clear coat into the scratch allow to dry wet sand w/ 2500 & buff (not agressive) ---assuming the scratch is free of contaminants works 99 out of 100 times. DO NOT GET THE CLEAR HOT W/ WHEEL!!!!!!!!!!
Just fixed some clear coat scratches on the wifeys black car today.Not deep,but wide.
I used the Turtle Wax Scratch Repair kit.Has some compound,3000 & 4000 grit sand paper and some sand paper lube.
I followed the directions and it turned out well using only hand pressure.Followed it up with some Megs polish & Ultimate wax.Looks good.
\db2
carolina
\db2
carolina
\db2
carolina
\db2
carolina
Welcome to the Forum, you may want to fill out your profile if you are going to stay. There are a lot of differnet solutions to your question, you may want to post in the detailing section. However, a good buffer with some quality paint compound/cleaners like Meguiars, Mothers, Griots, etc. will provide the power you need to get the scratches out. Auto geek sells a bunch of products that will help. Meguiars has specific videos on their site that show you how to use their products to do what you are trying to accomplish.
