leaking radiator overflow tank
I looked on different forums on here and could not find anyone mention a problem like I see on my car. If I drive just a few miles and come home, park in the garage, lift the hood and I will see water/antifreeze bubbling out of the radiator pressurized overflow tank. The tank show signs that it is leaking. Is this normal? Does not look right to me.
I had the same problem last year too. I removed the hoses an found that the tank had broke right where the hose connected. Wish I knew about rock auto cause I got one from the dealership =[
Received 19,217 Likes
'20-'21-'22-'23-'24
with the above. It is not normal for the tank to leak. Check for cracks and replace if necessary.
Rock Auto,Amazon automotive,forum parts sections. I don't buy parts from dealers unless its something only the dealership has.$50 for the tank from Rock Auto compared to $85-100+ is a no-brainer IMO. And also every so-often Amazon offers free shipping on some auto parts.
Wounded Warrior Escort '11
It is a pressurized system and should never leak as already stated. The tank does have a failure rate with cracking nipple tubes. I've not heard of any bubbling out the top though so its possible the cap is leaking so its probably best to replace both. I'm a bit concerned though with your bubbling. When you go to replace this tank, be sure to carefully burp the system to insure there is no trapped air in the engine. Past that, if you still have "ANY" bubbling, you'll need to get an exhaust gas test kit for the coolant.
