[Z06] 2004 z06 change battery
Old 05-04-2011, 02:02 PM
markymarq
markymarq's Avatar
Default 2004 z06 change battery
Hello
I'm not a frequent driver of my car, and my battery is dead. Is it easy to change the battery? On a scale of 1-10, and me being "handy", i'd give myself a 5.
or is it just better / easier / safer to have the dealer do it?
thanks
Mark
Old 05-04-2011, 02:36 PM
imavettegirl
imavettegirl's Avatar
do you really need to ask if it is hard to change a battery?
it is no harder than putting fuel in the car.
Old 05-04-2011, 03:28 PM
Yellow95
Yellow95's Avatar
I had a C4 and changing the battery was a little tricky. The C5 battery is simple, just take it out.
Note: the battery will go dead from lack of use because the car has a continuous drain on it. That does not mean the battery is bad, it may just need to be charged.
Old 05-04-2011, 04:18 PM
BitViper
BitViper's Avatar
These cars need fuel... hows that work!
Old 05-05-2011, 12:40 AM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Originally Posted by markymarq
Hello
thanks
Mark
Not hard at all...and get yourself a battery tender. My car is not a DD, so my battery can get tired sitting as well. I picked up a "battery tender jr." for $25. Worth every penny...starts strong all the time now.
Old 05-05-2011, 11:15 AM
garage-ghost
garage-ghost's Avatar
Not really a surprise. I was surprised to learn how many people don't even have a socket set in their house/garage.
Old 05-05-2011, 11:18 AM
garage-ghost
Just remember negative off first and on last.
Even a caveman can do it.
Oh, by the way the black one is the negative.
Old 05-05-2011, 03:50 PM
MillertimeZ06
MillertimeZ06's Avatar
7 year old battery, its time to change."You Can Do It"!!!!!!
Old 05-05-2011, 04:46 PM
2K3Z06
2K3Z06's Avatar
Location: KADS- If it has wings or an engine, I can break it. Dallas TX
Not hard at all.
But there is one small catch, be sure to write down the "unlock" code for your radio, if you have that enabled. My battery went dead, and after recharging. I had to unlock the radio. Good thing I wrote that down in the owners manual, back in 2002 when I bought the car. Cause I damn sure couldn't remember it, 7 years later.
Old 05-05-2011, 11:13 PM
MTPZ06
MTPZ06's Avatar
Originally Posted by 2K3Z06
Not hard at all.
Dealer can track that by the VIN, yes?
Old 05-05-2011, 11:20 PM
NatB
NatB's Avatar
Hello
thanks
Mark
Do yourself a favor and just have a store install the battery.
Go with an Optima - so no battery acid leaks.
Old 05-06-2011, 09:26 AM
DARRYLZO6
DARRYLZO6's Avatar
Real easy. Just swapped mine out to an Optima red top.
Old 05-06-2011, 09:45 AM
imavettegirl
if the battery died in the vehicle the code for the radio is a mute point.
you either know it or you don't.
Old 05-06-2011, 08:40 PM
Speedracer73
Speedracer73's Avatar
Old 05-06-2011, 11:49 PM
MTPZ06
MTPZ06's Avatar
if the battery died in the vehicle the code for the radio is a moot point.
Fixed
Old 05-08-2011, 01:33 PM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Make sure that the battery is secured tightly. You will think your whole suspension is coming apart if its not secured in there and flopping around.
Don't ask me how I know...
Toque
Old 05-09-2011, 12:28 AM
TheDVS1
TheDVS1's Avatar
I'd say you have a moot point vettegirl, cause, yeah, like you know it or you don't.
To 2004 z06 change battery
Old 05-10-2011, 07:46 AM
Vette Ed
Vette Ed's Avatar
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
my factory battery finally died...replaced mine last night. took me all of 7 - 8 minutes...use a 10 and 13mm socket. good luck
Naturally Vain (08-19-2019)
Old 05-10-2011, 08:03 AM
spdislife
spdislife's Avatar
DIY...beyond real easy.
Old 05-10-2011, 09:46 AM
zeeohh6ex
zeeohh6ex's Avatar
I give this a 1 on a scale of 1-10
Quick Reply: [Z06] 2004 z06 change battery
