No heat on Drivers side. Toasty on Passengers
Help. I recently puchased a 99 Vette and noticed that when I turn the heat on, the drivers side is cold while the passenger side is nice and hot. I disconnected the battery and reset the actuator but when i lower temp on the drivers side, it stay cold and will not blow hot again. any help would be appreciated.
If you have dual climate controls, check to make sure the passenger **** is not set all the way on heat. The dual control diverts heat to the passenger side if the passenger **** is set for higher heat.
