So i Plastic dip my car today at the shop. what you think
Old 03-26-2011, 07:09 PM
tech2262
tech2262's Avatar
Default So i Plastic dip my car today at the shop. what you think
SO today i was off of work and decided to head to work but not to work . I went in to plastic dip my rear portion of my car it was my first time using this stuff and it's some cool stuff actually.well here are some pics and the process i took hope this will help other ppl on here.
First before you tape off the are you will need a clean car.Then you will need to clean the area. I used glass cleaner and rubbing alcohol to get in the tight areas. Then you are ready to tape. Make sure your tape line is straight. and i went overboard with the tape off , trust me this stuff comes off , just use adhesive remover
2nd step. Make sure you have alcohol wipes or alcohol handy to clean the tip of the can so the tip doesn't get clogged in between coats. The first coat you want very light, at this point you will be like wtf have i done to my car, don't worry you can remove this with power washer if you dont like it. leave 12 mins in between coats. closer you get glosser further you spray it will be more textured.
Uploaded with ImageShack.us
the 2nd coat you will want to go much heavier with the coat make sure you get the vents good, they are a little tricky. It will start looking better at this point but don't crazy, cause you will want to do one more coat just like this
Ok last step while your third coat is still went you will want to pull the tape off, this were i had a little problem. I found the coat was starting to come up with the tape so I stopped and use a razor blade and very gently went around the tape. Be careful you don't score your actual paint, if you do it very light you will not have a problem. if some comes up not a problem you can just use a piece of card board and touch it up thats what i did. Allow overnight for fully cure, i was able to drive my car home from work with out a problem.
Old 03-26-2011, 07:15 PM
HG
HG's Avatar
that looks good, it breaks up the solid yellow.
Old 03-26-2011, 07:16 PM
Chuck A
Chuck A's Avatar
St. Jude Donor '08-'09
Chuck A approves
very nice, indeed
defenitely gives it some contrast
Old 03-26-2011, 07:17 PM
tech2262
tech2262's Avatar
thanks guys i have to hand it the product great stuff
Old 03-26-2011, 07:22 PM
vette.mix
vette.mix's Avatar
looks great
Old 03-26-2011, 07:27 PM
vettman96
vettman96's Avatar
That really does look good with the Yellow
Old 03-26-2011, 08:11 PM
AntonioZ06
AntonioZ06's Avatar
nice job. makes me feel more comfortable about trying it on mine. Just to make sure....if you spray it closer to the paint, it has a glossier finish? If you spray it from further away, it has a matte, textured finish?
I'm after a semi gloss finish, so just wanna make sure. Thanks
Old 03-26-2011, 08:17 PM
Monkey D. Luffy
Monkey D. Luffy's Avatar
Old 03-26-2011, 08:20 PM
csexton
csexton's Avatar
Well done
Chuck
Old 03-26-2011, 08:31 PM
GBsC5Vert
GBsC5Vert's Avatar
Location: LA/OC border, probably sittin' under the patio, by the pool...smokin' a cigar! SoCal
Looking good!
Old 03-26-2011, 08:43 PM
olbear1962
olbear1962's Avatar
Looks very nice, sets off the back end
Old 03-26-2011, 09:03 PM
Johnson 92
Johnson 92's Avatar
C5 of the Month 6/13
Looks good!
Old 03-26-2011, 09:04 PM
tech2262
tech2262's Avatar
AntonioZ06 nice job. makes me feel more comfortable about trying it on mine. Just to make sure....if you spray it closer to the paint, it has a glossier finish? If you spray it from further away, it has a matte, textured finish?
From what I heard that's how it works , I sprayed it 12 inches or so I would do more research on the glosser finish. Mine is flat
Old 03-26-2011, 09:52 PM
jacks996
Jacks996
Support Corvetteforum!
jacks996's Avatar
Cruise-In VIII Veteran
looks good with the blacked out lights
Old 03-26-2011, 11:59 PM
VETBLSD
Navigator
VETBLSD's Avatar
Haven't heard about this stuff. Is it a protective coating or what? Is it removable?
Old 03-27-2011, 12:03 AM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You did good and it looks great!
Thanks,Matt
Old 03-27-2011, 01:27 AM
Received 19,188 Likes on 13,911 Posts
'20-'21-'22-'23-'24
Nice job - the blacked out area goes really well on the car.
To So i Plastic dip my car today at the shop. what you think
Old 03-27-2011, 08:08 AM
jdbush23
jdbush23's Avatar
Looks good, just waiting for outside to warm up so i can do mine
Old 03-27-2011, 08:39 AM
trick89
trick89's Avatar
Where do you find this paint? Details? Looks incredible, nice ride!!
Old 03-27-2011, 09:51 AM
tech2262
tech2262's Avatar
U can find this stuff in any home improvement store I found it in ace and it wasn't in the spray can section odd. 100% removable u wouldn't even knew it was there
Quick Reply: So i Plastic dip my car today at the shop. what you think
