Fuse Size ????
Old 03-02-2011, 02:30 PM
Ole Blaster
Ole Blaster's Avatar
Default Fuse Size ????
I replaced fuse #23 (floorboard) with 10 amp. fuse that was blown and I was asked if that was the right size fuse (amp)... good question...After looking owners manual it dont tell you... where can I find out???
Old 03-02-2011, 02:40 PM
Jewjenk
Jewjenk's Avatar
Should be a template on the underside of the fuse box cover showing the size........If yours is gone , then try a search...................
Old 03-02-2011, 04:14 PM
Ole Blaster
shows the # not the amprage .. tried a search on fuses didn't come up... how do I word the search???? Thanx for replying
Old 03-02-2011, 05:31 PM
Ole Blaster
Originally Posted by 8VETTE7
Shop manual wiring diagram shows fuse #23 in passenger footwell fuse box ( BCM2) is 10A.
Thanks friend, I have replaced mine with the proper size (10A).. Is there anything published on-line that I get a copy?? Be nice to have and see if the rest are correct???
To Fuse Size ????
Quick Reply: Fuse Size ????
