LS1 Displacement
LS1 Displacement
I received a Corvette Poster Data Sheet for a gift and have a question. This poster shows the specs for Corvettes from 1953 through 2009.
It shows the '97 through '03 C5s as having a 5.7 litre 350 cubic inch engine, but shows the '04 as haveving a 5.7L 346 C.I. engine.
I thought all LS1 engines in the C5 were 346 cubic inches. So which is right: the poster or my memory?
All LS1 & LS6 engine are 5.7 liters. so if you have a 5.7 liter, you will have 346 cubic inches.
Thanks guys. I appreciate your prompt response.
P.S. The pictures also incorrectly showed some models of C4s with the HMSL (high mounted stoplight) which was not on approx '91 and later.
Overall I still like the poster which is framed and in my garage, even if it is not completely accurate.
Received 19,559 Likes
'20-'21-'22-'23-'24
All LS1 and LS6 engines were 346 ci. They were labeled as 5.7L too.
Hi Quick Draw -
Your memory is correct, and that poster data is suspect.
I have a similar poster, and I noticed right away that many of the pictures of the C5's on the poster have front calipers on both ends.
It looks good on the wall, and should not be used as a reference.
best regards -
mqqn
best regards -
mqqn
Hi Quick Draw -
best regards -
mqqn
best regards -
mqqn
Received 3,112 Likes
St. Jude Donor '21-'22
