Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-25-2011, 06:30 PM   #1
hp_performanceparts
CF Senior Member
Default 241 Heads vs. 243 Heads
What is the difference between 241 casting heads and 243 casting heads?
hp_performanceparts is offline   Reply With Quote
Old 02-26-2011, 12:50 AM   #2
HowlinC5
CF Senior Member
HowlinC5's Avatar
241 heads were used on '99 and up LS1's. The 243's were used on LS6's and had sodium filled exhaust valves. I think the valves were larger as well.
HowlinC5 is offline   Reply With Quote
Old 02-26-2011, 01:41 AM   #3
whitehooptie
CF Senior Member
whitehooptie's Avatar
Not all 243's have the sodium filled valves. In the early LS2's, they used the 243 with a standard valve.
whitehooptie is offline   Reply With Quote
Old 02-26-2011, 01:44 AM   #4
TriplBlk
CF Senior Member
TriplBlk's Avatar
243's(LS6) flow better than the 241's(LS1)
TriplBlk is offline   Reply With Quote
Old 02-26-2011, 06:21 AM   #5
baxsom
CF Senior Member
I see on ebay 243 heads that say that came off of a 5.3 that say they are casting 799 but just need the valves and springs to be the same as a LS6. What is up with those?
baxsom is offline   Reply With Quote
Old 02-26-2011, 08:48 AM   #6
nobreaks254
CF Senior Member
241, 243 and 799 castings all have the same size valves.
243/799 have slightly small combustion chambers than 241. 64cc vs 66cc iirc.
nobreaks254 is offline   Reply With Quote
Old 02-26-2011, 10:40 AM   #7
04 commemorative
CF Senior Member
04 commemorative's Avatar
Quote:
....I'm going with.....2...
04 commemorative is offline   Reply With Quote
Old 02-26-2011, 11:20 AM   #8
~Josh
CF Senior Member
~Josh's Avatar
'01zo6 cars got solid valves like the LS2, 02-04 Zo6 got sodium filled exhaust valves, same solid intake valves.
~Josh is offline   Reply With Quote
Old 02-26-2011, 11:37 AM   #9
TriplBlk
CF Senior Member
TriplBlk's Avatar
Wait,were the only sodium filled valves, exhaust side only?
Old 02-26-2011, 01:44 PM   #10
R6cowboy
CF Senior Member
R6cowboy's Avatar
Yes, exhaust side only
Quote:
241 heads were on the C5 ('01 thru '04 and some late '00)
243 heads were on the Z06 ('01 thru '04)
Combustion chambers - 66.67 (241) / 64.45cc (243)
Intake port volume - 200cc (241) / 210cc (243)
Exhaust port volume - 70cc (241) / 75cc (243)
Intake flow at .600" - 227 (241) / 257 (243)
Exhaust flow at .600" - 180 (241) / 183 (243)
The 243 heads have a D-shape exhaust port that improves flow and came with higher lift valves springs
Both heads came with 2.00" intake valves and 1.55" exhaust valves
To my understanding, this is all the difference.
R6cowboy is offline   Reply With Quote
Old 02-26-2011, 02:10 PM   #11
madmatt9471
CF Senior Member
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 734 RWHP & 585 RWTQ-----1/4 10.34 @ 135 MPH (New ET Eventually!)
If I remember correctly the LS6 (243) stronger spings than the LS1 (241) -
Hands down the LS6 head flows better than the LS1 due to the runner volumes and the smaller combustion chambers!
LS6 heads are refined and improved LS1 heads, basically:
- Intake runner volume increased to 210cc vs. 200
- Exhaust runner volume increased to 75cc. vs 70
- Combustion chamber is smaller at 64.45 cc vs 66.67
- Compression ratio is higher at 10.5:1 vs. 10.1:1
- "D" shaped exhaust ports vs round
If you mill the deck on the LS6 head 0.030" you will get 11.1:1 compression.
Flow #'s (Stock heads @ 28") Head vs Lift
Head/.200/.300/.350/.400/.450/.500/.550/.600
LS1 / 137/ 187/ 207/ 223/ 228/ 237/ 242/ 243
LS6 / 156/ 204/ 225/ 243/ 257/ 268/ 275/ 278
In short smaller and more efficient combustion chamber allows quicker burn times, requires less ignition timing resulting in higher torque.
Thanks,Matt
madmatt9471 is offline   Reply With Quote
Old 02-26-2011, 09:12 PM   #12
TriplBlk
CF Senior Member
TriplBlk's Avatar
Honestly though are the sodium valves even worth bragging about? I feel so dumb now, I had a so-called buddy sell me hand ported Ls1 heads, milled,and lS6 springs( I use to think daaammn)...now all I think about is...what a waste of money, same as this damn GM ASA cam with it
Old 02-26-2011, 09:25 PM   #13
Capthuff
AMP Racing member
St. Jude Donor '09-'10-'11-'12
Capthuff's Avatar
well, IIRC, the sodium valves weigh 74 grams and the standard valves weigh 97 grams. You might not think this is much, but, it's about 31% more weight. Might not seem like much, but at 7000 rpm, it's a lot...
Capthuff is offline   Reply With Quote
Old 02-26-2011, 09:47 PM   #14
TriplBlk
CF Senior Member
TriplBlk's Avatar
What does less valve weight do though? less chance of valve float??
Old 02-26-2011, 09:56 PM   #15
Capthuff
AMP Racing member
Capthuff's Avatar
No, that would be spring pressure.
lighter weight valves require less spring pressure and require less force to open and close them. So, the engine makes more power.
The reality of this is that most of us will never build an engine to the point that this will make any difference at all in what we are trying to accomplish. Really, how many people actually build engines and car combos to extract the absolute most they can no matter the cost?
Nascar, NHRA, F1, IRL, ALMS, they do it.
The only person I know of that even thinks in this relm is RobZ.
Old 02-26-2011, 09:59 PM   #16
02*C5
CF Senior Member
02*C5's Avatar
02-04 243 heads had the hollow intake valve and sodium filled exhaust valve. This was for better valve-train geometry and stability since the ZO6 was reeving to 6500 rpm.
02*C5 is online now   Reply With Quote
Old 02-26-2011, 10:11 PM   #17
TriplBlk
CF Senior Member
TriplBlk's Avatar
Quote:
He's not the one footing the bill though, isnt that what "AMR" is for?
thanks for the info though...
Old 02-26-2011, 10:44 PM   #18
Capthuff
AMP Racing member
Capthuff's Avatar
I think Rob would argue that point with you...
Old 02-26-2011, 11:10 PM   #19
TriplBlk
CF Senior Member
TriplBlk's Avatar
I wasnt trying to state it as a fact, I just thought that was for the sponsors, or at least mostly. Either way its an expensive build no matter who's paying..
Old 02-27-2011, 01:44 AM   #20
00 Rooster
CF Senior Member
St. Jude Donor '08
00 Rooster's Avatar
that is a lot of good info hope fully I can use it some day.
00 Rooster is offline   Reply With Quote
Reload this Page 241 Heads vs. 243 Heads
Tags
241, 243, 243s, 799, asa, cam, cc, corvette, exhaust, flow, heads, ls1, ls6, port, sizes, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
