Race Ramps & lowered Vette?
Will the 56'' 2 piece Race Ramps work on a lowered (stock Bolts) Vette? Are do you need the extenders? Also is the Corvette forum the best place to buy them?
Thanks Guys.
Thanks Guys.
ramps
My car is not lowered. Had to use a 2X12 plus 1/2" plywood attached to get on my Race ramps without rubbbing. Ordered the extenders later. Works easy with those. Got mine from Brute.
Get the 67" if you want the extra 2" in height. If your car is really low, you'll still probably need the extenders either way. My Z is lowered 2" on Pfadts, and the 56+ ramps and extenders work perfectly for me!
I have the 67" 2 piece with extenders and my Vert is lowered on Pfadts. I still barely scrape the black spoilers under the bumper but other than a four post lift this is the way to go. RR's are solid and very well designed. Gotta be safe when you crawl under any vehicle.
I have the 56" with the extenders.
Just using the 56" ones I had to remove my front lower black faring piece on both sides. My car sits.... Lowwww.
Now I don't have to with the extenders.
These things are great I find. They weigh about 1 lb... seriously !
They are feather light. Hang them off the ceiling on a hook if you want.
Both the 56, and 67 have a 10.75 degree incline.
So unless you want your car up an extra 2 inches It might not be worth the extra $$$
XTenders nest right into your one or two-piece 56” or 67” Race Ramps, giving you an approach angle of only 6.8° for use with vehicles really low to the ground. They mate easily with the 56” or 67” Race Ramps and can be removed once the vehicle is up the ramp to provide additional working area.
Toque
Toque
Thanks for the info Mark, do you wish had the 67'' or is the 56'' good enough?
The extender's came in super handy because it drops the approach angle down enough for my lowered car to drive up without having to remove the black front lower fearings.
Toque
