Last night my horn went on while the car was parked inside the garage. Anyone ever have this happen to them? Why did it start to beep? What needs to be done?
Thanks..............this make some sense. I'll try to locate the bladder switch and replace.
I had the same problem. I noticed that the membrane had impressions from the back of the horn pad pressing against it. I flipped the membrane over and this allowed the horn pad to strike the membrane in different spots. Or, you could replace the membrane entirely. They run about $60.
