Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-11-2011, 05:16 AM   #1
linf94112
CF Senior Member
linf94112's Avatar
Default Yonaka Racing Seats Installed Pics and Installation Process
The following will just be sort of a visual DIY guide or just helpful visuals for the installation process of the Yonaka Racing Seats for the C5 Corvette. I have included some notes in the photos, so hopefully that helps. This will serve as a reference for those planning or thinking of replacing your seats.
See them in person! - I live in the San Francisco area, and basically anyone that would like to see how these are in the car in person and even test them out by sitting in them is welcome to. The final fitment and set up in the car are according to the photos shown below, so any other variations for installation will provide different space of course. Just email me instead of a PM: frank.ymlin@gmail.com.
Please excuse my elementary welding neatness, I have been self teaching and have not had too much practice.
I have had these installed for over 2 years now and they are still in excellent shape. There has not been any tears or rips and everything is still snug. I have the REAL LEATHER version of these seats.
NOTE: There are others who have installed these in a slightly different process, including cutting the interior trim pillar to relocate the seat belt retractor for more space to mount further back, and also another with a thinner mounting bracket that does not include the use of the stock feet brackets.
I have considered the thinner brackets after my fabrication because the end result is that it does sit about 3-4 inches higher than the stock seats, which would be uncomfortable for taller people. Also, for those taller than 5'8" or 5'9", I would recommend relocating the seat belt retractor in order to install these further back to get more leg room.
As for me, I am 5'7" and actually sit PERFECTLY comfortable in the seats with slightly improved front and side visibility due to the slightly higher seating.
Click the image to open in full size.
linf94112 is offline   Reply With Quote
Old 02-11-2011, 05:16 AM   #2
linf94112
CF Senior Member
linf94112's Avatar
Frank.
Old 02-11-2011, 05:16 AM   #3
linf94112
CF Senior Member
linf94112's Avatar
(Reserved)
Old 02-11-2011, 05:24 AM   #4
joecaver
CF Senior Member
St. Jude Donor '08-'10
joecaver's Avatar
Location: 63.8% of all statistics are made up on the spot.
the seats look very nice. Do you race or do you just like the look of those seats?
joecaver is offline   Reply With Quote
Old 02-11-2011, 05:29 AM   #5
linf94112
CF Senior Member
linf94112's Avatar
Quote:
I like the look of the seats, but the major reason why I changed them out was because the previous seats were not working, cushions were beyond flat, and there were rips and tears in them. They were also bothering me with how much crap that seemed to be encrusted throughout them.
Now I actually have cushion for my butt.
Old 02-11-2011, 11:47 AM   #6
ez2spd
CF Senior Member
ez2spd's Avatar
I ordered these from Dennis will be installing once they arrive next week, where did you get this piece of metal from.. I see the sku on it so I assume a retailer..
ez2spd is offline   Reply With Quote
Old 02-11-2011, 03:23 PM   #7
SoDiezl350
CF Senior Member
Nice work! What did you use to drill out the rivets that attach the stock mounting feet to the OEM seat brackets?
SoDiezl350 is offline   Reply With Quote
Old 02-11-2011, 05:39 PM   #8
ez2spd
CF Senior Member
ez2spd's Avatar
Quote:
grind them off, thats all I did... worked like a charm... I just cant find the metal he used for the frame support I checked locally at home depot and lows
Old 02-11-2011, 05:55 PM   #9
ez2spd
CF Senior Member
ez2spd's Avatar
im 6'0 185lbs so I think that using the factory rails will put my knees in the steering wheel but well find outttt...
Old 02-11-2011, 08:43 PM   #10
dobewillie
CF Senior Member
dobewillie's Avatar
Super job and post thanks
dobewillie is offline   Reply With Quote
Old 02-14-2011, 05:36 AM   #11
linf94112
CF Senior Member
linf94112's Avatar
Quote:
Correct with getting the rivets out. I cleaned up any smaller bits of metal with a dremel to get the brackets off.
As for the metal, I did in fact get it at Home Depot. They have it with the area they usually keep the threaded metal rods, angle steel and aluminum metal pieces, flat metal, and such.
You may even have to go to more than one Home Depot and even try a Home Depot Pro location just to check in case they do not have enough in stock since these things dont get reordered so quickly.
Hope that helps.
Old 02-14-2011, 05:41 AM   #12
linf94112
CF Senior Member
linf94112's Avatar
Since you are 6' tall, I suggest probably even looking into cutting the plastic pillars covering the seat belt retractors and relocating that further back to get a little more legroom.
As for seat height, you should try to have the factory metal feet placed on top of the C-Channel metal and any other height reduction you see along the way for the seats to get you some more space.
The other option is using flat metal and none of the factory metal feet. Drill a hole for the rear mount location, get some 90 degree bends in front to mimic the original metal feet in front and then bolt down. This may give u an extra 2 inches of head and leg space.
Frank.
Old 02-14-2011, 07:00 AM   #13
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
Nice job modifying them to work in your car. They look so much better than the stock seats.
Vetteman Jack is online now   Reply With Quote
Old 02-18-2011, 01:36 PM   #14
ClockworkC5
CF Senior Member
my seats just came in and they look great. i got the white stitching and i cant be happier with them. i got them from Dennis w/ double din, and he's been a great help so far. i would definetly recommend using him. ill post up if i find anything diffrent in my install.
ClockworkC5 is offline   Reply With Quote
Old 02-18-2011, 11:51 PM   #15
ez2spd
CF Senior Member
ez2spd's Avatar
I ordered mine from him too they got here at 6pm and right now both brackets are made driver is a flat bracket with no riser but seats will not fit with out removing factory belts... I am installing harness bar to fix this, I also cut and tac welded seats for more room no biggie for me though
will post pictures as available
Old 02-19-2011, 07:04 PM   #16
ez2spd
CF Senior Member
ez2spd's Avatar
passenger seat done, hardest part is marking holes on bracket for slider with the seat in the car... holes have to be 14 1/4" apart but too far one way or the other and seat won't match up... I used the factory brackets on passenger side and see what everyone means with it being taller, my head is inch or so from top, good thing my girlfriend is 5'6" 110 bc it fits her... she is not happy with wearing ''5 point but she will get used to It lol or walk''
Old 02-19-2011, 09:23 PM   #17
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Quote:
Very niceClick the image to open in full size.
peter pan is online now   Reply With Quote
Old 03-03-2011, 12:08 AM   #18
ez2spd
CF Senior Member
ez2spd's Avatar
sorry it took so long to upload ONE CELL PHONE PICTURE.. but they are installed and I LOVE THEM!!! Will have better pictures tomorrow once I get out the EOS
Old 03-07-2011, 05:45 AM   #19
linf94112
CF Senior Member
linf94112's Avatar
looks so snuggly! haha - Cant wait to see the pair photo.
Old 03-07-2011, 05:11 PM   #20
ez2spd
CF Senior Member
ez2spd's Avatar
Work has been INSANE, I got the pictures taken just need to upload them, so project tonight and tomorrow is that )
Reload this Page Yonaka Racing Seats Installed Pics and Installation Process
Tags
brackets, c5, corvette, custom, diy, drag, install, installation, installations, installing, race, racing, seat, seats, yonaka
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
