Yonaka Racing Seats Installed Pics and Installation Process
When your install was finished how much space was there between the seat and the trans tunnel? I'm thinking that if we can shift the seats inward towards the trans tunnel 3/4 of an inch or so that it will help decrease the amount of cutting and trimming on the outer side that's required to fit the seats and possibly even be able to leave the outside adjusting **** and seat belt plastic alone
I'll try and get my pictures up tomorrow... my seats are so tight against tunnel seats are not adjustable... only I drive so not an issue... don't get me wrong they will move with force lol its just a tight fit had I went half inch other way they would move easIer
Also, the inside where the recliner wheel is on the final photos, it has been reduced already. The outside just had no space so it had to go inside, and while the wheel is shortened, there is still a few mm from touching the tunnel because the side and lap bolsters are already pressed against the transmission tunnel.
In summary, the outside ****'s plastic piece cant be left, and the **** also doesnt have much space unless the car's trim piece was cut.
Frank.
Frank.[/QUOTE]
I basically got that exact same answer from another member, thanks. For the feedback. They look really good installed
Frank.[/QUOTE]
The driver side I didn't use brackets I bolted the provided sliders to the floor and put a steel brace on the under side of the car... perfect height... passenger side I used factory riser as the tunnel has a 4 inch piece coming off it... makes since when you see it
Thanks!
#33
Interesting on the bolting to the floor. Id like to see pics of this.
#34
has anyone gotten in touch with Arizen to see if their universal brackets would work with these seats??
#35
im about to tackle the install this tomorrow if i get the time. im curious if anyone else has done the seats and has some more info. if i read a post correctly its possible to attach the sliders that came with the new seats to the factory bolts in the floor. is this correct. if anyone has any additional input it would be greatly appreciated. thanks
#36
#38
I have this car now and these exact seats and belts are for sale. I am simply too big for them.
All the cutting and measuring and everything will be done for you and you will save some money as I just want to trade straight across.
Want to trade for some C6Z or C5Z stock seats in excellent condition. these are about 2 months old.
I am located in OKC.
Thanks!
#39
