Installing the console power outlet?
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
How does the consoles power outlet get installed? I have a customer finished one back from the shop and the power outlet has two tings in it but the hole for it only has one cutout for a single ting which is 90 degrees out of position for the poweroutet. Is it just a straight push it in till it snaps in place ? Really confused and I don't want to break it. Thank you !
Oldtimer
power outlet install !
Thank you ! Forum saves me again !
Jim Ward
Received 19,307 Likes
'20-'21-'22-'23-'24
Some things can be frustrating at first, can't they? Glad you got the outlet installed.
Thank you, Worked like a charm. I did notice as I was sitting here pondering my dilemma, that if you look at the sideways at the power outlet, one of the tabs sit just a %$$hair farther back from the other, so I put that one in first then twisted it and sure enough there's just enough 'Give' that you can carefully & slowly twist the outlet till the other one is in and then it's just a half turn back and the two tabs are locked it.
Jim Ward
Jim Ward
Oldtimer
1997 Console without the notch in it.
Oddly enough, I have another custom finished rear console that has slightly smaller opening for both the power outlet & the gas door switch ? I'll have to use a small file and put a notch in the burl-wood finished console and put it up for sale on Ebay. This forum is an excellent place to get real world information on the C5 from C5 owners.
