XYZ Big Brake Kit Thread! **Owners/Customers post in here!**
Former Vendor
This thread is for pictures, info, and feedback on the new Big Brake Kit from XYZ available for the C5 and C6 Corvettes! If you have purchased a kit, post your pictures in here, install steps, videos, whatever you have to share to help out others interested! If you have questions on these systems, post up!
St. Jude Donor '11-'12-'13-'14-'15
Here's my prototype set installed to compare. the new sets are an improved design
Jon and I both wrestled with the OEM rear rotors, those parking brake shoes are a major PITA! My right side hung up so bad that I broke the "A" shaped hold down spring for the shoe, luckly my local dealer had one laying around and gave it to me, otherwise you have to buy a complete parking brake shoe kit to get a new hold down spring!
Make sure your parking brake is disengaged obviously and loosen the rotor by smacking the hat with a hammer, repeat as necessary!. You have to pull the rotor straight off, if it gets cocked a tiny bit it'll catch the shoe and hang up...
Here's a little info on the parking brake system;
http://www.queencitycorvette.com/Tec...Adjustment.htm
Tim
Tim
Cleaning Your Hubs
Here's a tip for you not only for installing BBKs but for a rotor swap as well. We had these rotors made to pretty tight tolerances so I had to get the crud off the Hubs... I used a round wirebrush attached to a drill to clean them up pretty well first and also the bracket mounting ears;
Here's something I noticed, these chunks of rotor still attached to the Hub is bad news!
If there is a build up of this stuff on one side it'll certainly give you a vibration! Scrape this stuff off!! I used a razor blade and then wirebrushed the Hubs again!
It'll be on your mounting ears also, here's a great example... Look how one chunk is only on one area, this would have thrown my Caliper mounting off and possibly caused a runout issue;
Ready for new rotors now, except for that top caliper mounting ear!
Tim
Tim
Shimming the Calipers
After you get everything installed measure the distance between the inner caliper faces and the rotor to determine how neutral your caliper is sitting. Mine were like this;
One of the smaller round shims (See below) between each caliper bolt and the mounting bracket made it damn near pefect.
Tim
Tim
Former Vendor
Former Vendor
Good call!
Tim
