Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-07-2010, 03:24 PM   #1
skyavonee
CF Senior Member
skyavonee's Avatar
michaelschiavoni
Default Best tool for cutting exhaust pipe while still attached to car?
I figure an exhaust pipe cutter won't work since I won't be able to get all the way around the pipe at the top where it's closest to the car's floor (right?).
Torch is no good since I would likely hurt myself or the car.
So a reciprocating saw is my only option... right?
skyavonee is offline   Reply With Quote
Old 12-07-2010, 03:28 PM   #2
memphis_vette
CF Senior Member
memphis_vette's Avatar
maybe a grinder with a big cut off wheel?
memphis_vette is offline   Reply With Quote
Old 12-07-2010, 03:33 PM   #3
srs244
CF Senior Member
St. Jude Donor '09-'10-11-'12-'13-'14
Support Corvetteforum!
srs244's Avatar
i use a pneumatic 3" grinder and it works well. basically all you need to do is work the sides of the pipe and you can then get across the top without a problem. the 3" is small enough to be able to get into tighter spaces so it works well.
srs244 is offline   Reply With Quote
Old 12-07-2010, 03:35 PM   #4
dougbfresh
CF Senior Member
Sawzall
dougbfresh is offline   Reply With Quote
Old 12-07-2010, 03:38 PM   #5
Patches
CF Senior Member
Patches's Avatar
Quote:
Originally Posted by dougbfresh View Post
Sawzall
Patches is offline   Reply With Quote
Old 12-07-2010, 04:00 PM   #6
imavettegirl
CF Senior Member
imavettegirl's Avatar
sawzall or something like it.
or, go to exhaust shop.
imavettegirl is offline   Reply With Quote
Old 12-07-2010, 04:01 PM   #7
84REDCROSSFIRE
CF Senior Member
84REDCROSSFIRE's Avatar
Sawzall
YUP
84REDCROSSFIRE is offline   Reply With Quote
Old 12-07-2010, 04:12 PM   #8
wcsinx
CF Senior Member
wcsinx's Avatar
I used a chain type cutter when I installed my x-pipe.
Plenty of room ... worked like a charm
Click the image to open in full size.
wcsinx is online now   Reply With Quote
Old 12-07-2010, 04:25 PM   #9
skyavonee
CF Senior Member
skyavonee's Avatar
michaelschiavoni
Excellent! This is exactly what I wanted to use but was afraid wouldn't be able to get around the top of the pipe. I'm installing a Borla X-pipe, hopefully this weekend.
Thanks all for the responses
Old 12-07-2010, 05:01 PM   #10
CBILLY1
CF Senior Member
CBILLY1's Avatar
I second the "chain type" pipe cutter. I just did a Corsa X-Pipe and Corsa Indy Pace Car mufflers. Without this tool it would have been much more difficult. If you have an "Oreilly Auto Parts or similar store, check their "tool loaner" program. I borrowed the tool...brand new never used for a small deposit! Worked great!
CBILLY1 is offline   Reply With Quote
Old 12-07-2010, 05:16 PM   #11
wcsinx
CF Senior Member
wcsinx's Avatar
There's plenty of room between the pipes and tunnel to swing the chain over. (A sawzall would actually require more room) I borrowed the tool from Autozone.
Old 12-07-2010, 05:21 PM   #12
Bills03Coupe
CF Senior Member
Bills03Coupe's Avatar
This is definitely the way to go. Makes a clean cut, without any jagged edges. Very little clearance is needed to swing the chain over the pipe.
Bills03Coupe is offline   Reply With Quote
Old 12-07-2010, 05:28 PM   #13
Atok
CF Senior Member
Atok's Avatar
Send a message via MSN to Atok
Chain cutter is the correct tool. They work great. Just be sure to oil it well when you're cutting. They don't work well when dry.
Atok is offline   Reply With Quote
Old 12-07-2010, 05:30 PM   #14
STALION
CF Senior Member
STALION's Avatar
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
Reciprocating saw with a proper blade is your best option. I watched my mechanic cut my pipes in a tight spot and it went through like a hot knife through the proverbial butter! It was a nice clean cut to. Good luck.
STALION is online now   Reply With Quote
Old 12-07-2010, 06:49 PM   #15
CHJ In Virginia
CF Senior Member
CHJ In Virginia's Avatar
Quote:
This type of chain cutter is your best option. It is quick, delivers a clean cut, and does not give any chance of torching anything. They are available for less than $30.
__________________
2003 Black on Black Z06 track car - Sold to a good racer home in Maryland.
Replaced by a 2008 loaded black on black coupe.
CHJ In Virginia is offline   Reply With Quote
Old 12-07-2010, 07:50 PM   #16
Tech
CF Senior Member
Tech's Avatar
I've used all of the methods suggested and the chain cutter is the best in my opinion. It's hard to get a perfectly straight cut with a sawzall and the pipes can bounce causing the blade to bind.
Tech is offline   Reply With Quote
Old 12-07-2010, 08:17 PM   #17
damilleniumboy
CF Senior Member
damilleniumboy's Avatar
pretty
damilleniumboy is offline   Reply With Quote
Old 12-07-2010, 09:42 PM   #18
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
Sawzall
Should do the job just fine - just take it slow.
Vetteman Jack is offline   Reply With Quote
Old 12-07-2010, 10:09 PM   #19
b18c1950
CF Senior Member
best thing ever i have the snap on one
b18c1950 is offline   Reply With Quote
Old 12-07-2010, 10:38 PM   #20
VTX DOUG
Junior Member
VTX DOUG's Avatar
I went to Autozone - they rent tools like the chain cutter and pipe expander. They run you credit card for the cost of the tool and when you return it they credit it all back to your card. Hard to beat Free.
I needed the pipe expander to get my X pipe on.
VTX DOUG is offline   Reply With Quote
Reload this Page Best tool for cutting exhaust pipe while still attached to car?
Tags
attached, autozone, car, cut, cutter, cutting, exaust, exhaust, pipe, pipes, reciprocating, tool, tools, vtxdougcom, work
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Z06 Stock Exhaust TheBiz C6 Parts for Sale/Wanted 8 05-01-2014 11:48 AM
wheels or side pipes 4 speed C3 General 24 10-14-2013 04:48 PM
'66 gm exhaust pipes socal66 C1 & C2 Corvettes 5 11-23-2012 08:05 PM
WTB 2010 or later NPP exhaust MarkDFW C6 Parts for Sale/Wanted 4 10-29-2012 11:51 AM
3" pipe on NPP, anyone do it yet ? bdanyluk C6 Tech/Performance 20 09-01-2012 10:49 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
