Best tool for cutting exhaust pipe while still attached to car?
Old 12-07-2010, 11:04 PM
skyavonee
skyavonee's Avatar
Originally Posted by VTX DOUG
I went to Autozone - they rent tools like the chain cutter and pipe expander. They run you credit card for the cost of the tool and when you return it they credit it all back to your card. Hard to beat Free.
I needed the pipe expander to get my X pipe on.
Nice to know
Old 12-08-2010, 07:41 AM
runner140*
Support Corvetteforum!
runner140*'s Avatar
Originally Posted by dougbfresh
Sawzall
I used a "Sawzall" on my C4 to install the Magnaflows.
Old 12-08-2010, 08:47 AM
A Marsh
A Marsh's Avatar
Hard to beat a grinder and cut-off wheel
Old 01-11-2013, 06:47 PM
hockeyspokes
hockeyspokes's Avatar
Originally Posted by CBILLY1
I second the "chain type" pipe cutter. I just did a Corsa X-Pipe and Corsa Indy Pace Car mufflers. Without this tool it would have been much more difficult. If you have an "Oreilly Auto Parts or similar store, check their "tool loaner" program. I borrowed the tool...brand new never used for a small deposit! Worked great!
I will be doing my Corsa Xpipe soon. What size chain cutter should I look for ? 14" handle 16" 18 " ??
Old 01-11-2013, 07:06 PM
Mattie Num Nums
Mattie Num Nums's Avatar
I got a sawzall for 29 bucks from Harbor Freight and a pack of blades. Some WD40 and 10 seconds is all it took.
Old 01-11-2013, 07:20 PM
Bill Vett
Bill Vett's Avatar
Thread is 2 years old......
Old 01-11-2013, 07:27 PM
sonny557
sonny557's Avatar
Default s
Sawzall
Old 01-11-2013, 07:31 PM
johnson-rod
johnson-rod's Avatar
I like the idea of the chain cutter but I use a pneumatic saw.
Old 01-26-2013, 08:22 PM
hockeyspokes
Default tool
Originally Posted by wcsinx
I used a chain type cutter when I installed my x-pipe.
Plenty of room ... worked like a charm
Anybody kknow where I could get one of these chain cutters used.
New is a bit pricey just for 2 cuts :<(
Old 01-26-2013, 08:58 PM
JETninja
JETninja's Avatar
WA Events Coordinator
Old 01-27-2013, 12:35 AM
Vetteriffic
Vetteriffic's Avatar
Originally Posted by sonny557
Sawzall......Worked like a charm for me....
Old 01-27-2013, 02:02 AM
racebum
racebum's Avatar
chain is easier to re weld. when i was just out of HS and working in a shop all we did was sawzall exhausts. exhaust pipe has a lot of carbon and junk in the steel from the engine running. when you go to reweld with carbon steel and 75/25 gas it spatters and is just that much harder to keep a clean bead going. the smoother the cut the easier it is to reweld. also, if the exhaust is stainless use 308 wire and helium trimix if you can. the 75/25 will introduce some carbon into the weld. it usually won't rust too much if you use 308 wire but it will more than using helium
shops use the sawsall because they are fast. the chain cutter will take 5x a long to use but it's much cleaner
Old 01-27-2013, 08:19 PM
  #33
ROJ#79
ROJ#79's Avatar
Old 01-27-2013, 08:41 PM
  #34
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Originally Posted by skyavonee
I figure an exhaust pipe cutter won't work since I won't be able to get all the way around the pipe at the top where it's closest to the car's floor (right?).
Torch is no good since I would likely hurt myself or the car.
So a reciprocating saw is my only option... right?
Reciprocating saw would be my choice
Whatever you do, put a piece of metal at the top so you do NOT punch a hole in the floor board - regardless of where you cut!
It's for a protection!
Thanks,Matt
Old 01-27-2013, 09:01 PM
  #35
Rookieracer
Rookieracer's Avatar
Stopped in at Autozone today, the chain type cutter is $50 to purchase. As a rental, you have 90 days to return it for a full refund.
Old 10-30-2016, 02:52 PM
  #36
dieterschmied
1st Gear
dieterschmied's Avatar
This is the best answer! Second would be to google exhaust pipe cutter.
For most respondents, I would never let them touch any of my cars. Geeze!
Old 01-24-2020, 01:47 AM
  #37
LoveLee One
1st Gear
LoveLee One's Avatar
Default Which blades
Originally Posted by STALION
Reciprocating saw with a proper blade is your best option. I watched my mechanic cut my pipes in a tight spot and it went through like a hot knife through the proverbial butter! It was a nice clean cut to. Good luck.
What blades are the best to use with the Reciprocating saw,? Lately I've been using my sawzaw and it's pretty loud and I find myself having to change blades in between cuts
Quick Reply: Best tool for cutting exhaust pipe while still attached to car?
