Passenger door coming unglued??
Cruise-In 9-10 Veteran
St. Jude Donor '08-'09-'10
this is the passenger door...any idea why its doing this and is there any way to fix itshort of replacing it (which I can't do right now)
agreed, common issue and the door panels are another discontinued item by GM. I ordered some from APSIS. Drop me a PM if you want detalis on that transaction.
Received 2,688 Likes
2018 C5 of Year Finalist
Common problem especially if you live in warmer climates. Same thing has begun to happen to my 04' vert which really pisses me off considering the car is so well maintained, garage kept with low miles.
I'm even more angry that GM has already discontinued parts for a 6-year old car.
As mentioned, you have various options. You can pull off the door panel, drill holes and inject epoxy (there was a previous thread/right up) or you can replace the door panels.
Apsis provides high-quality Nappa leather options. Great looking, however a pricey alternative.
I have already spoken with a local automotive upholsterer who quoted me $500 to replace/reskin the vinyl, replace/repair the foam backing and swap out the lower door panel vinyl with a custom, mod red. I plan to do this when I get ready to swap out my seat skins and install the sound deadening material. Right now I will just live with the doors as they aren't too bad (yet).
Received 1,681 Likes
That's an age old common C5 problem.
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Another option I have seen is to buy a set of arm rest inserts.
http://www.ecklers.com/corvette-door...1997-2004.html
Alternatively, it may have been a situation wherein GM, realizing the warranty claims/poor quality arising from the particular vendor was costing them too much, actually cut THEM off and coincidentally could not find another vendor willing to tool-up and produce these items for a few more years and maybe were also even scared of GM's poor credit rating(s) about that time and didn't want to do business with them anyways.
There's often more to parts availability than meets the eye.
Given the enormous financial crisis GM has been experiencing over the recent years, do you think it possible the vendor that was actually doing the manufacturing of these panels for GM, cut off selling to them? I'll wager GM was taking longer and longer to pay their bills. Not to just their door panel vendor, but to everybody.
For example, I was (still am) searching for a torch red passenger side door speaker grill as part of a mod-red conversion project I would like to complete. I have checked with many vendors and GM no longer produces the part. Most vendors don't stock these and are simply online portals to GM for ordering.
My question is what happens if a 2004 Z06 owner with mod red interior has a slight fender bender that damages the passenger door resulting in a repair and replacement of the door panel? "Sorry, you can only order it black". The car is only 6 years old! Same holds true with those owners with oak, shale and AE interiors.
I'll be considering a solution like Apsis, etc next year.
Yep, that's what I meant by sticking up. You aren't solving the problem, just sticking something over the area which will not lay down flat without repair.
If that's true, I wish these vendors would step up and make themselves known.
An easy solution for you on your speaker grills is to unbend the mounting tabs on the back, remove them and take to a powder coater. Very durable finish. I have done this myself with a custom color. Find a powder coater and check out their color palette you can choose from. You'd be surprised how many colors are available.
My driver's door is loose in the center section. You press in on it, you can hear it stick then pop comes off again. Sort of bowed there now.
Your's appears different at that location creating almost a seam ripple.
I wondered about removing the panel and seeing how difficult it would be to some how feed some spray glue into the cavity and pressing it back together.
Here's a picture I have of mine, you can see the bulge in the center of the panel:
Thanks everyone for your responses and suggestions. I had a feeling that replacement would be the preferred option. But, its nice to know that in not alone with this problem
Nope, your not. '04 vert started doing it about a year ago... going to fix it and replace the horn pad by the end of the year.
I recall a thread a while back about the same thing. The OP's pic looks EXACTLY like mine.
It may have been Lonestar and some others that we discussed methods to try to reglue these? I haven't tried yet but I have to pull my passenger side off soon so may give it a try if I can think up a way to get some adhesive in there and smooth it out before it dries.
May not work but worth a shot before just giving up on them.
Definitely not alone. My 04 started it last year.but it's daily driver and sits in the elements all year. I figured that it was making it come apart faster.
Premium Supporting Vendor
Hi Guys,
This is a common problem. What happen is when GM formulate their fomula for the parts they add some special additives and such additives kill the adhesion that cause such delamination.
When we wrap the leather, we remove the vinyl completety and then we inject the form material to the whole door panel and carefully sand it to fill the same thickness. It takes lots of labor but once it's done it will guarantee you won't get delamination any more.
Most venders just glue the leather direct to the vinyl and it will still delaminate.
If you are interested in upgrading your door panel to the nappa leather, it will become very beautiful and well worth the money.
Jersey
Jersey
