Will Z06 rear quarters fit on a Convertible?
Looking to find out if they will fit and what other additional parts would be needed... we have customer looking to replace his convertible quarters with the wider Z06s
Thanks.
Thanks.
If you are asking about C5 fenders, the answer is NO. The Z06 fenders are not any wider but where they mount up top by the roof, there is a difference where they curve up to mount. I recently investigated this exact situation because I wanted to change the fender on my Z.
I actually did know you could trim the 'vert fender but if that's the only difference you can just get the correct fender and not worry about an inept bodyman to mess things up. I was wondering if the OP thought the Z fender covered a wider tire like a C6 Z06 does. The reason I checked this out is because I wanted to put a coupe right rear fender on my Z06 to eliminate the antenna without body work, since the fender was being replaced anyway due to being backed into. I resolved it another way and now do not have an exposed antenna.
