***Stealth Light Cannons V2 - Most awesome headlights ever! (In Development)
#141
Supporting Vendor
I wanted so bad to do red on my car, but I decided it wasn't worth the risk even for my personal car.
#143
George,
When I placed my order before you stopped the first GP I opted for the Halos but would definately like the amber halos and definatly with the demon eyes look. If I need to add to the PayPal funds just let me know.
Jim
Jim
#144
This is possible. I can get the shroud material in Black or white ABS. Either can be painted, but the base color should be picked based on what color the paint will be. For instance: Yellow should be painted on a white shroud and blue would do well on a black shroud.
Where do I send cash an when will they be ready to ship.
M
#145
Supporting Vendor
I'll put your name on the Priority list. You will receive a PM or Email once the GP starts. I'm planning for the GP to start in 1-2 weeks.
#146
Supporting Vendor
Radical new option
Here's the latest headlight option I'll be you've never seen:
"Terminator Eyes"
The front of the projector's cutoff shield is what's seen through the lens. By painting the front of the shield, it makes the projector lens appear that color. Installing a red rear-facing red LED will make the projector appear to glow red.... "Terminator eyes"
This type of light is indirect or "refracted" light. MOST states do not have regulation that prohibits this for colors other than white or amber. You should check your local DOT laws if you plan on using a different color. Other suggested colors are blue, red, green, UV(purple)
Option Price: $100
Can be combined with all other options.
"Terminator Eyes"
Option Price: $100
#149
Supporting Vendor
Base kit: $1275
Options (add to base price)
Secondary Fog package "A" $120 (for cars that already have foglights)
Secondary Fog Package "B" $250 (for ZO6 cars and others without OEM foglights)
Hyper vision package $250
Halo rings: (white or amber) $150
Demon eyes halo mod: $50 in addition to halo option
Terminator Eyes: $100
Options explained
Secondary Fog light package “A” - (+120) - Convert your inner projector to an auxiliary fog light or rally light using a modified flat cutoff shield and a 3000K HID bulb for a golden-yellow color. Kit “A” comes with a harness to tap power from your OEM fog light circuit. Optionally, you could run a relay harness and install a switch in the cabin (harness and switch not included)
Secondary Fog light package “ZO6” - (+250) Specifically for ZO6 or non-fog light-equipped cars. Includes a Relay harness that taps into thee existing fog light circuit and a GM Fog /trunk switch for the cabin enabling your car to work as though it had fog lights from the factory. No splicing or cutting is required to install this kit.
“Hyper Vision” Package – (+250) The Bad-*** of the headlight world. Features a quad bi-xenon setup where both inner and outer projectors are low and high beams. Nearly 12,000 lumens of output…that’s FIVE TIMES as much output as the stock headlight setup….and with the SLC v2 projector pattern. These are the brightest production headlight for ANY car made.
Halo Rings - (+$150) install CCFL Halo Rings on each projector. Amber or white available. (Taps into your parking lights so you can cruise around in style.
Demon eyes halo mod: $50 in addition to halo option: Paint over the INSIDE of the halo casing showing only 3/4 of the halo ring giving an evil eye appearance. (pictured on the black car with the amber halos above)
Terminator Eyes: $100 By painting the front of the shield, it makes the projector lens appear that color. Installing a red rear-facing red LED will make the projector appear to glow the selected color. Red, Amber, Blue, Green and UV colors available.
#150
Base kit: $1275
so i am wanting the base with halo lights . whats the hyper vision package? whats the difference in the demon eyes and terminator eyes? and whats deal with that? you have to paint the cover black or your car color to achieve those looks or are they coming already painted or covered etc from you like that?
Rick
#152
Supporting Vendor
i am confused!!!
Rick
Rick
The "demon eyes" is a modification to the halo rings only. you DO NOT need to paint the main lens to get this effect. I just decided I liked the look on my car.
Note: both the main lens and Shroud are paintable but i DO NOT offer a painting service for those parts. You will need to have your body shop do that work if you choose to have them painted.
#153
Appears I am down with Hyper Vision with Halo Rings and Terminator Eyes. Sweet.
Question with the Terminator Eyes. Is this something that can be turned on and off individually or do they come on when you turn your lights on?
What base color would you recommend for Pewter?
#154
Supporting Vendor
#157
Supporting Vendor
Not at the moment.
#158
I hate to ask as I feel like I am just pestering you but with the terminator eyes, is this something that turns on with the park lights? Do the lenses look red when the low beams are turned on? Is it possible to have the terminator eyes on an entirely separate switch so they can be turned on and off independently of everything else? If not a totally separate funciton, I may have to pass on them as I do see issues with legality. I am excited about the halos and hyper vision. CAN'T WAIT!
Thank you very much George for the time you have put in with answering our questions. I'm looking forward to the end product and having these lights on my car.
#159
Supporting Vendor
Yes, This is the default setting.
No, the low beam overpowers the Red.
Yes this is possible. Alternatively, you can also hook up the Terminator eyes to the high-power positive wire on the turn signal. The terminator eyes would function as the DRL then shut off when the parking lights/headlight were turned on.
