[Z06] Widest tires you can put on the rears?
Old 09-27-2010, 07:01 PM
02corvettez06
7th Gear
02corvettez06's Avatar
Default Widest tires you can put on the rears?
The original size being 295/35/18, how wide can you go in the rear?
thanks!
Old 09-27-2010, 07:09 PM
James92
James92's Avatar
Old 09-27-2010, 07:10 PM
RedZMonte
RedZMonte's Avatar
If your including stock wheels of 18x10.5 then i would say 315's are the widest you would want to go. The tire will Crown like hell when going to wide, and you would not benifit from the wider tire because you will be mostly riding on the center of the tire. Ive read alot of guys run 305 on the rear, maintain good wear and have good traction.
Old 09-27-2010, 07:42 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Old 09-28-2010, 04:06 AM
JETZ
JETZ's Avatar
305!
Old 09-28-2010, 08:01 AM
JiminVirginia
JiminVirginia's Avatar
thanks!
I've got 335/30/18s as my rears for autocross, mounted on 12 inch CCWs, running a 1/4 inch spacer. Yes, they stick out a bit. Car is lowered about half way on stock bolts.
Old 09-28-2010, 09:56 AM
CarsRFun
CarsRFun's Avatar
305/30/18 ???? whats the side wall for the 305 on stock rim?
Old 09-28-2010, 03:29 PM
Shad
Shad's Avatar
315/35/18 Toyo TQ Drag Radials.
Car up in the air, it was NOT rubbing on the rear Z06 brake duct. It's got about a 1/4"-1/2" gap when the car is on the ground. I'm lowered all the way on stock bolts, and I have ZERO rubbing issues.
Old 09-29-2010, 10:07 PM
CarsRFun
CarsRFun's Avatar
bump whats a good 305 street/strip tire guys?
Old 09-29-2010, 11:39 PM
bud miller
bud miller's Avatar
305's on stock wheel..downside the rear side of car gets blasted from rocks etc..from tires due to width..solution is apsis spashguards..
but they are pricey...
bud
Old 09-29-2010, 11:50 PM
NeoZ06
NeoZ06's Avatar
305's, anything wider will stick out past the fender and if you are too low, you may crack a quarter panel...
Old 09-30-2010, 06:18 PM
Omaha02Z06
Omaha02Z06's Avatar
http://www.discounttiredirect.com/di...5R+Drag+Radial
They are a good combo tire IMO. The sidewall is a little soft for spirited driving but once you get use to the initial roll over feeling as you go in to a corner too hot they're fine. I've only driven in the rain a few times with them but as long as you don't do anything stupid you'll be fine.
Old 09-30-2010, 06:47 PM
Paul 75 L82
Paul 75 L82's Avatar
I have the 315's on mine.
Old 09-30-2010, 07:25 PM
zeevette
zeevette's Avatar
I've got 19x11" rear wheels, but these fit
Nitto Invos...325-30/19, same overall diameter as stock. No rubbing, no cutting of the ducts, and fully lowered on stock bolts.
Old 09-30-2010, 10:09 PM
Shad
Shad's Avatar
That is interesting!!! I have 19x11.5" CCW 505a's and I was about to trade them down to 18's so I could run a 315/35/18 drag radial. How well do those stick for a street tire????
Old 10-01-2010, 01:41 PM
zeevette
zeevette's Avatar
You might want to go ahead with your plan to trade for 18" ers, if you can't get a good DR in 19". Invos are a great street tire, but not for drag racing. They seem to like the twisties, and even a wet road better than straight ahead grip. There are several brands now making that size, though. You might want to check out.
Old 12-22-2010, 11:16 PM
vinweb
vinweb's Avatar
jiminvirginia - what SCCA class are you running in with those 335/30/r18(s) and what are you running on the front?
Thanks,
Vince
To Widest tires you can put on the rears?
Old 02-19-2018, 05:52 PM
AnthonyZ0620
AnthonyZ0620's Avatar
Did you use these for street use? I’m considering buying them. As my r888 are coming to an end. Wondering if these are good for a summer
Old 02-19-2018, 06:55 PM
Verrückt ZR1
Verrückt ZR1's Avatar
Zombie thread.
AnthonyZ0620 (02-28-2018)
Old 02-20-2018, 01:52 AM
JETZ
JETZ's Avatar
Some ‘noobies’ can’t read.
frank
Quick Reply: [Z06] Widest tires you can put on the rears?
