[Z06] Z06 rear partition
Old 09-21-2010, 07:07 PM
Blackkaz04
Blackkaz04's Avatar
Default Z06 rear partition
hey guys my Z came with a rear partition. How do I get it out. it is in there tight! I pushed from the back then from the front and it wouldn't budge. I know how these simple things go if you rush, I do not want to brake it. How should it come out? thanks,
Old 09-21-2010, 07:11 PM
hotwheels57
hotwheels57's Avatar
Depending on the manufacturer, it could be a press fit, held in with snaps or VELCRO. Push inwards along the bottom edge. The snaps or VELCRO are typically along the top edge. They usually install from the cabin side.
Be careful, it could be foam board rather than a wood product.
Old 09-21-2010, 07:33 PM
tlove32
tlove32's Avatar
Probably velcro. Pop the trunk and give it a good push along the edges - it'll move forward enough for you to get it out
Old 09-21-2010, 10:16 PM
Blackkaz04
Blackkaz04's Avatar
Thanks, I got it out by pushing it forward. It had a line of velcro underneath. Took a bit to get it out. But it is unscathed. Now to see how loud it is without it.
To Z06 rear partition
Quick Reply: [Z06] Z06 rear partition
