tunnel plate insulation
Old 09-14-2010, 04:22 PM
futuretech
futuretech's Avatar
Default tunnel plate insulation
I am looking for insulation to put on the inside (torque tube side) of my tunnel plate to cut down on the heat. I don't mind using the bolts to hold it on. I am just looking for something that can handle wet and freezing weather.
Suggestions?
Old 09-14-2010, 04:28 PM
c5BlackBeauty
Corvette C5 Enthusiast
Support Corvetteforum!
c5BlackBeauty's Avatar
St. Jude Donor '05, '12-'13, '15-'16, '21
Do a search for Forum Vendor Elite Engineering and take a look at the insulated replacement plates they offer. Much thicker/stiffer than the stock and they offer several with different grades of thermal coating. Many of us on the Forum have gone this route. Additionally, if you have the inclination you can insulate the cockpit to really do it up right. Do a Search and you'll find a ton of posts on insulating.
In terms of adding a product to the existing stock plate I personally haven't heard of anyone doing this and frankly not certain its possible for the long haul. I believe you'll find going with an after market plate with the option of adding insulation is the way to go.
Old 09-14-2010, 09:21 PM
JimZRyd
JimZRyd's Avatar
St. Jude Donor '12
Yes. Take a look at the Elite Enginering stuff. Amazing the difference in their plate and the stock plate. Good time to do an exhaust upgrade too if you are in the market for one.
Old 09-14-2010, 09:39 PM
jrprich
jrprich's Avatar
Take a look at SummitRacing.com or Jegs
http://www.jegs.com/webapp/wcs/store...hTerm=89314001
Old 09-14-2010, 10:24 PM
waunavet
waunavet's Avatar
St. Jude Donor '20
Suggestions?
Don't think you'll need it. I put in the EE 1/4" coated plate. I also insulated the top side (under console) with Frost King-type insulation. Cut the heat transfer and noise significantly.
Old 09-14-2010, 10:41 PM
jmzvet
jmzvet's Avatar
I did the FrostKing mod and bought the plate but never installed it.
I still have the plate and will sell it for $20,000.
It includes a nicely modded C5
Old 09-15-2010, 02:03 PM
msgvert
msgvert's Avatar
I saved this DIY from the forum but have not tried it yet:
DIE Floor Tunnel Shield
1)Remove tunnel plate and write top on the top side of the plate.
2) Place tunnel plate over center of sheet of DEI heat shielding (adhesive backing facing up).
3) Trace outline of tunnel plate and "most" of the bolt holes along the perimeter.
4) Look at DEI material and make a free-hand line just inside all the bolt holes about 1/2-3/4"
5) Take a knife and carefully cut the adhesive backing protector along the free-hand lines you created and remove adhesive backing ONLY from the middle (see photos at bottom).
6) Place tunnel plate with "TOP" facing up, carefully over exposed adhesive backing using original tracing lines. Once lined up press onto the DEI material and press down along the entire tunnel plate.
7) Flip over and fold "wings" inward to expose your bolt holes. Trim wings down as desired.
8) Re-install tunnel plate bolts.
9) Press wings against tunnel sides to keep heat away from both the top and sides of the tunnel. You're done!!!
Here is a gallery of photos:
http://www.pbase.com/callaway/tunnel
I've done this twice and I didn't secure them in any other fashion. Mine has held for 10k miles with no issues. The material is rigid so it holds it's form once you get it pressed against the sides of the tunnel. A rubber mallet can be helpful but watch what's behind the material. I've seen some people put a couple rivets in on the ends of the tunnel plate. Although the one I did in the photos we took to a Kansas City performance shop to install. The idiot at the shop removed the backing even though you can clearly see we wrote on both sides to not remove it. He said he thought it looked better No telling how we will get that tunnel plate out.
I used the DEI 010412 48"x36" it runs about $52 at Summit Racing.
Old 09-15-2010, 05:49 PM
futuretech
futuretech's Avatar
Thanks for the info guys. Has anyone considered just putting two stock plates together with insulation in the middle?
To tunnel plate insulation
Quick Reply: tunnel plate insulation
