[Z06] Looking for best 160 deg. thermostat
Can some one point me in the right direction for a quality 160 deg thermostat. I see some are available with out the housing. For simplicity I'd like to buy one with the housing.
Thanks!
Thanks!
SLP makes one too.
OK now I am confused. Does anyone know if they changed the thermostat design in 2004? They all list 97-03 and say will not fit 04 model. Then they offer 04-10 with the thermostat separate from the inlet pipe. I can't remember if I have ever changed one on an 04 so I do not know if its part of the pipe or not.
Hmm, I will call the dealer and see whats up. Thanks!
Well I talked to the Chevy Dealer parts dept. and according to their parts explosion it lists the thermostat separate from the water inlet pipe.
Ended up being incorrect. The genius behind the phone used a 2000 Corvette thinking all C5's were the same. Came as an assembly with housing, and did not show a listing for an Alt. temp thermostat for the 2004.
Looks like you are correct.
I would be looking for a 170* T-stat instead, 160 is too cold, your oil does not get hot enough and you also will have a lot of variation in temperature especially when your cruising and then you come to a stop light. Get your fans adjust with the 170* and you should be as good as gold
No, this applies anywhere. Cooler is not always better, I would look into this more before you ignore what I said. Look up the sweet spot.
