Coolant Change Questions
Just called up some dealership/shops and found prices between $150-$200... So I guess I'm just gonna do it myself
I've already seen some threads on it but just wanna make sure...
First, we need the dexcool and distilled water.
Then we need to raise the front of car, open up some cap underneath and then drain the fluid.
Close cap, then fill it up with dexcool and distilled water. Run engine, fill more, etc.
The details I know are listed somewhere so I can look it up again. But got a few questions.
1. Where do you get distilled water? I don't have a water filter..
2. How to not make a huge mess?
3. Any special steps to pay more attention to?
Thanks!
Thanks!
Received 19,439 Likes
'20-'21-'22-'23-'24
Distilled water can usually be bought at almost any grocery store.
DEXCOOL is good for 50 or 100k miles I think. Do you really need to change it?
I put a big Costco clothes washing detergent bucket under the car when changed my thermostat awhile back. Most of the coolant ran into it (with a little help of a DIY aluminum foil kind of funnel to direct it to the bucket).
..rickko..
I know the DIY'ers out there will cringe and disagree, but changing coolant is one of the few jobs I will let others do on my Z. There is a small Chevy dealership near by that deals mostly in Corvettes and has a great Corvette mechanic, and I have no problem letting them do the job for $150 or so, especially since it's only needed once every 5 years or 100k miles. Small price to pay... And if they screw up, it's on their dime, not mine! Just my 2 cents...
$150 is not a bad deal, plus you don't have to deal with disposal, etc.
Use a 3/8" socket extension (no socket, just the square end) to open the drain valve. It only opens a 1/4 turn so be gentle. The valve is about an inch about the drain hole facing the rear and will be white plastic. Super simple to do.
Personally I think changing the coolant in these cars is easier than the oil. If you put a drain under the radiator you won't miss a drop.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
My local Chevy dealer wanted $200 for the coolant change. Wound up letting my Pontiac
dealer do it for like $90. Now they're out of business but I'll probably be in a C6 by the time I need to get another one. Whatever you do, don't let anyone do a power flush and
change, that's a no no.
Jerry
Jerry
If you are an avid do it yourselfer, this is a simple procedure.
I have done this several times already on my '04.
Do youself a favor and do this while the engine is cold or at least cool.
You can expect some spillage fumbling with the stupid drain plug.
If you havn't seen it yet you will probably be asking "is that it".
There is a better replacement plug for it that you may want to have ahead of time in case you have a problem with the stock plug, and the replacement has a tap to make future changes much easier. Do a search and you will see it. In any case, when you do the quarter turn or so counter clockwise, you may have to pull outward slightly to get some flow. A bit a wiggling and another quarter turn, and you can remove the plug entirely. Have fun and save the money. I switched to Prestone universal, and replaced the Dexcool. You can even get it premixed 50/50.
Just had my 04 done at a local dealer for $100.
Excellent time to pull the radiator and clean all the grass and bugs out of it and the AC condenser.
The purists will cringe but I flushed mine good with water and went with regular Prestone antifreeze. The kind that says it is compatible with any type or color antifreeze. No problems at all and I will just service it every two years or so. Where I drive the radiator may need the fins cleaned that often anyway. Ever since I bought this bottom feeder it seems everybody in the world wants to mow their grass with the side chute pointing at the road.
but I believe it's a 1/4 drive not 3/8
Thanks!
Thanks!
Got my car at 43k miles, has 73k now (2001 A4 Coupe). Recently did Trans, and diff and wanted them to do the coolant. They checked it, said it tests fine, it looks clear pink to me, so I let it go.
It is possible it was changed before I got it (around 43k), but the Dexcool does last a long time. Never had a coolant related problem.
According to the C-5 Corvette Specs a C-5 holds 11.5 quarts of coolant. If you are only changing what is in the Radiator I would purchase 2 gallons of Dexcool Premix to add to replace what you remove. If you need more you can always buy more. Still new to the C-5 but in the older V-8s we had drain plugs on the engine which made it easier to do a complete flush. From what I read it is different with the newer aluminum engines such as the LS1 etc. I don't think there is access to any coolant drain plugs. Have to check to see were I am with the C-5 I purchased 3 weeks ago. I may just do the same and replace what is in the Radiator with Premix Dexcool.
