What Kelvin HID'S Are You Running
Old 07-11-2010, 07:49 PM
BenC5
BenC5's Avatar
I started with 6000K 35W in my low beam Light Cannons. The output was weak.
I then went with 5000K 35W and it was better than the 6000K.
I finally went with 4300K 55W and am going to stick with it from now on.
I have 4300K in my foglights and the combination is perfect for me as I drive a lot at night and in the rain at night.
Old 07-12-2010, 01:20 AM
corvettedaddy11
corvettedaddy11's Avatar
I think 5000k lows and fogs will be my choice!!!Thanks Guys!!
Old 07-12-2010, 09:13 AM
0TheRadioFlyer97
Former Vendor
TheRadioFlyer97's Avatar
St. Jude Donor '08
1.Are all the hid kits made the same, Example ebay kits 50 bucks ,2 local shops ones 100 bucks for low's and another shop is 150 for low's does it really matter
Most HID Pnp kits are similar quality. Just about every one comes from about 5 large factories in china or elsewhere in asia. The only differencees are how much the merchant wants to charge.
2.Is 8000k low beams and 6000k fogs too bright
The brightness is not what you have to worry about. it's the glare proeduced by using HIDs in your oem healight housings. This glare hampers your long distance vision and may cause night-blindness. You really need a projector-based kit to get the most out of your HID bulb.
Consider this comparison pic:
3.Simple pros and cons
Pros: Longer bulb life (~2000-3000 hours) 2-3x total lumens output.
Cons: If used in a proper projector housing, none.
4.What kelvin is against the law if any!!
Many states have laws against "blue" lights, but that's up to the officers opinion of what is blue. I had one trooper pull me over for having "blue" tag lights. I had to explain to him they were white LEDs. I would avoid anything higher than 6000K to be on the safe side. Also remember that anything higher than 6000K also has significantly less visible light output.
5.Whats a good hid brand?
For what you're wanting to do, there is no distinct difference in brands. If you were using OEM equipment in a true retrofit (D1 or D2-series bulbs) You'd want Hella or Matsu****a Ballasts and Philips or Morimoto bulbs.....but you won't find these in plug-and-play setups.
Old 07-12-2010, 09:18 AM
Polar Jet
Polar Jet's Avatar
I went with 6000k lows and fogs from JWM and could not he happier.
Old 07-12-2010, 09:48 AM
Spoon83
Spoon83's Avatar
That is probably the best choice!
I have a 35watt 6000k kit now and it does not put out enough light through Depo projectors. I plan to buy a 4300 or 5000k kit in the near future.
Old 07-12-2010, 10:09 AM
904pizza
904pizza's Avatar
10000k low, 5500k fogs if I'm not mistaken.
Old 07-13-2010, 03:00 AM
JMc
JMc's Avatar
Location: "This is not a psychotic episode, but a cleansing moment of clarity."
An excellent decision you will not regret.
Old 07-13-2010, 08:16 AM
tonylukes3
tonylukes3's Avatar
6000k here in the lows, however I'd go with the 5000k 55w or 4300k next time. The 6000's are better than stock halogens but not as bright as I'd like. Oh well
Old 07-13-2010, 04:42 PM
SCM_Crash
SCM_Crash's Avatar
10,000?!?! Isn't that pretty much like dark blue or purple?
Old 07-13-2010, 04:53 PM
904pizza
904pizza's Avatar
Yeah it's blueish!! But with the Depos I'm seeing OK so far.
Old 07-15-2010, 02:52 PM
mtndv8
mtndv8's Avatar
I agree, great choice!
I'd recomend the 55 watt set-up...
Old 07-15-2010, 04:45 PM
rpm462
rpm462's Avatar
Originally Posted by JMc
I'm running 5000k 55w mains and 4300k 35w in my fogs. 6000k were too dim for me - gave me eyestrain. 8000k would lead me to suicidal thoughts from the eye strain. The higher in kelvins you go, the less light you are putting on the road in usable lumens and the more "blue" it is, the more it will be sucked up by the blacktop.
JMc, would you mind PM'ing me where you got your 5000k's from. I've still got the 4300k in my low's and you're right they do look pretty yellow and would like to swap them out with something closer to my 6000k foglights.
Old 07-15-2010, 04:48 PM
  #33
JW Motorsports
Banned Scam/Spammer
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Are you using stock housings? I have 5000k bulbs if so.
Old 07-15-2010, 05:19 PM
  #34
rpm462
rpm462's Avatar
No, I have the ACA housings.
Old 07-16-2010, 05:57 AM
  #35
Jistari
Jistari's Avatar
As I understand it 4300 is white and the most light output, anything above that is technicaly "not white" so there is some blue in there. If an LEO wanted to be a stickler, they do have ways to test it (a card they can hold ifo the light and if it isnt white, you can read the text, if its white light...no text..like that). It probably boils down to what they look like, if they look blue, its just another reason to get stopped (just an opinion).
Also as you increase watts, the lights get a little whiter, so 4300k at 35 watts will look similar to 5000k at 55 watts, so you can get away with higher than 4300k if you're running higher wattage.
Dont have them installed but they are paid for and on the way, 4300k lows and halogen highs, in projectors.
Quick Reply: What Kelvin HID'S Are You Running
