ok what did i just get myself into?
St. Jude Donor '12
i have had my car for almost 5 years now and it has been all stock up untill i got stupid and went e-bay happy and started reading posts on this site a few weeks ago. i loved my car!! then it happened, i bought my first mod then my second then my third and then..................!! so here is my question for all, just how much is this going to cost me? when does this sickness go away? what mods have you guys done so far and how much have you spent? what mods. are you the happiest with? what mods are you ashamed of admitting you did? just currious. feel free to post pics.
St. Jude Donor '05
Hi, my name is Mike and I'm a modoholic.......... short answer> there is no end, there is no cure...........
Originally Posted by diviniti
It will never stop. You now have the modifiers bug. Its like a drug addiction. You want more, and more, and more, and need to do more and more and more. Say bye to the bank account, and HELLO Money Pit.
Hi, my name is Doug, (loudsam). I'm a modoholic too! There's is nothing I've done so far that I regret, but, I've done alot of research before I did/had done/ the mods that have been done. I've spent in the neighborhood of 9 to 10 thousand dollars above the cost of the car. I don't think it will ever end, but, I've slowed down a little for the time being!
“Resistance is futile, you have been assimilated into the collective called the Borg Vettes.” You have fallen into the trap as the rest of us have. I too was naïve once and thought I could resist the Borg Vette, but no one can resist.
Mods done to date:
1. Rear window tint
2. Sound dampening kit
3. Custom stereo system with Ipod
4. Stainless Steel letters front and back
5. Painted fuel rail covers
6. Painted air bridge C5 emblem
7. Painted C5 emblem on hood liner
8. Z06 replica chrome thin spoke wheels
9. 3D C5 emblem on steering wheel
10. 3D CORVETTE letters on the air bag
11. Chrome tip exhausts
12. Cup holder
Mods left to do:
1. Paint brake calipers
2. Chrome exhaust plate
And there will be more to come I am sure, it never ends!
Mods done to date:
1. Rear window tint
12. Cup holder
Mods left to do:
Location: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Uh-oh! The mod bug has bit you and now you're infected. It's going to cost a lot and I don't think you can be cured...ever.
Mods I've done? Let's see, not too much yet but I've only had the car for 11 months...
Borla quad round tip stinger cat back exhaust
Corsa X-pipe
20% window tint
Painted calipers
Blackouts all the way around
Acrylic lettering front and rear
Steering wheel decal
Door sill decals
Air bag cover decal
Best mod for me thus far would definitely have to be the Borlas. Cheeziest mod? That would have to be the stoopid acrylic lettering. Started falling apart about a month after I put it on. Looked cheap as he11 too. If I was to do it again I'd go with the SS inserts. But now that I've had them off for a while it keeps looking better and better with nothing on it.
BTW, I've got some bilstein sport shocks, a Halltech Stinger and some LGM Lt's on back order. I'm also in the process of researching camshafts and after that will begin my quest for heads.
Corsa X-pipe
20% window tint
Painted calipers
Door sill decals
Air bag cover decal
Dont even try, , dont, it wont work. The more you try, the more you spend.. Got to go, I think my SSR wheel/tire set just got here.
Nope, not yet, just the kid next door... Maybe tomorrow they will be here...
Darn, it never STOPS..
5 years??? You're a better man than I am. I lasted all of 1 week. It all started off very innocently with a license plate frame, then floor mats, a few stickers....now 5 years later, I find myself with new wheels, air intake, exhaust. Now I'm getting headers, high flow cats & x-pipe. Going with 3.42 gears later this year...It never stops!!! And most of these mods were done way before I discovered the CF. The forum only fuels the fire!!!
This is a list of what I've done so far. It's a dark and lonely road we travel....
External Engine:
VaraRam 1B w/K&N filter.
Smooth airbridge coupler
C5 Carbon Fiber Airbridge
Carbon Fiber Radiator shroud cover
Carbon Fiber Fuel Rails
Nick Williams 90mm Throttle Body
FAST LSX90mm Intake (ported & matched to heads) painted Satin Black
85mm descreened MAF
Performance Hood Seal (to keep my engine cleaner)
Throttle Body bypass (NW throttle body has no coolant pipes)
30lb/hr SVO flow matched injectors.
NGK TR6IX plugs
Taylor Spiro-Pro plug wires
Heatmaster wire shields
Reworked LS6 valve covers (for Jesels)
AMW catch can
ASP underdrive pulley
Ultra Lightweight starter
Odessy 925T battery
Kooks 1 3/4" headers, hiflow cats, and xpipe
Borla Stingers
Internal Engine:
AFR 205 heads, milled .030" w/ Ferrea lightweight valves.
.040" Cometic head gaskets
Jesel SS shaftmount roller rockers
TR 7.350" hardened pushrods
Comp 850 lifters
Pistons notched .065"
ARP Pro Series Rod bolts
Comp XER 224/228 .581"/.588" 112LSA cam installed on 112ICL
Cloyes Hex-Adjust timing set
JWIS timing chain
Katech ported LS6 oil pump w/bypass shimmed .060"
LS6 PCV conversion
Transmission/Driveline:
Spec Stage 3 clutch
Fidanza Aluminum flywheel
Z06 Slave
4:10 gears
Hardened output shaft
DTE Transmission Strut
Frame, Chassis, and Suspension:
A&A Tunnel reinforcement plate
Z06 springs
Z06 swaybars and endlinks
QA1 HAL 12 way adjustable shocks
Goodridge Stainless Steel brake lines
Lowered 1"
For the street:
GM Performance drilled and slotted rotors
AC Delco Quiet Stop ceramic pads
Z16 Speedlines triple chromed w/ Z06 size Pilot Sports
For the Track:
Stock Rotors
Stock pads
CCW Drag Package
Interior:
B&M Ripper shifter
Mallory Billet C5 shift ****
Lloyds Mats
Black/Torch Red Steering Wheel skin
Black/Torch Red accented console lid
Torch Red accent welt
Torch Red dorr handle pulls
Bolt 300w stereo amp
12" JBL subwoofer
amp and sub mounted with quick disconnects (for race days)
8" JBL mid-bass/mids (in doors)
2" JBL tweeters (front firing in roof riser behind the seats)
15% tint on side windows
10% tint on rear window
Exterior:
Black Painted Calipers
SilverStar Headlamps and Highbeams
Euro style taillights (red/amber)
Euro style side markers
Chrome C5 Exhaust Plate
Black 3D rear lettering inserts
Zaino
Computer/Tuning
LS1Edit
EFILive V6
EFILive Flashscan V7.2
PLX M250 O2 Wideband and controller
External Engine:
85mm descreened MAF
NGK TR6IX plugs
AMW catch can
Odessy 925T battery
Borla Stingers
Internal Engine:
Comp 850 lifters
JWIS timing chain
LS6 PCV conversion
Spec Stage 3 clutch
Z06 Slave
4:10 gears
Z06 springs
Lowered 1"
For the street:
For the Track:
Stock Rotors
Stock pads
CCW Drag Package
Interior:
B&M Ripper shifter
Lloyds Mats
12" JBL subwoofer
Exterior:
Zaino
Computer/Tuning
LS1Edit
EFILive V6
St. Jude Donor '12
Received 1,680 Likes
They'll just keep making stuff you'll want to buy!
Welcome to our world. I'm amazed that you made it the first 5 years with your car stock. I lasted a month.
BTW Trigger Creep, that pic in your sig is awesome!
Happy modding!
UT-Driven
Happy modding!
UT-Driven
