How to Apply 3M Carbon Fiber Wrap
#41
1 Post
St. Jude Donor '12
Thanks for the reply. I have to say again and again what a great job you did with your door bezel! It looks perfect So did you only put the primer on the edge of the door bezel or on the entire surface? I was thinking of doing the center console and that is one big unit....so would you recommend doing the entire surface or just around the edges and corners? Indy
http://forums.corvetteforum.com/c5-g...-interior.html
and check it out. Use 1 piece, big enough to cover the whole thing and TAKE YOUR TIME! Take everything apart do the appurtances separately (ash tray door, drink door & temp sensor). Start and the bottom and primer at the vertical contours (ash tray area, A/C area and radio). Wait to end to primer/tuck the tabs to the back side. Don't hesitate to ask me for help.
Good luck and post some pics my Vette brother! - C.A.
#45
Gonna do this to some underhood stuff!
Great write-up
Thanks,Matt
Great write-up
Thanks,Matt
#49
1 Post
St. Jude Donor '12
You're right. The material is "self-sticking". With that said, the amount of adhesion you'll get is enough to lay down on a flat or low-contoured area and still be able to lift it again and re-apply if you goof it up. When you're stretching onto a highly-contoured area, you'll need some help keeping it down as it will want to lift on its own. (i.e. under the brake handle.) That's where the primer comes in.
#51
Thanks for the write-up! Doesn't look too hard. I think I'll try it out on a couple pieces in my commuter car first to see if I like it. I imagine this is a case of "practice makes perfect"
#52
BTW, when you do these pieces and/or the console, do they need to be sanded down first. I've heard the carbon won't hold for a long period of time because the surface isn't flat and the textured surface allows air to get under it. Is that right?
Great write-up also.
tracer1
#53
1 Post
St. Jude Donor '12
Thanks so much for the info.....I have a sheet of it & just haven't gotten around to using it. Now I know I need the primer. Thanks.
tracer1
tracer1
Long story short, pass on the sanding. It is not necessary. The 3M primer in the high-contoured areas is all you'll need. - C.A.
