Custom Gauge Faceplates- From JWM
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
no longer offered @ jwm
Received 2,688 Likes
2018 C5 of Year Finalist
been thinking about these for awhile, any pics of the el glow with metallic silver dial (prefer red font) lit up? just curious of what it will look like all lit up
Just a question...
on the speedometer, shouldnt MPH be physically below KMH? I think thats how it is on my vette. If so, will this cause the MPH speedometer speed while illuminating the letters KMH?
All Aboard!!!
I do not have directions but if you put the needle into the hole and slide it on you can push down a little on the face plate and it will pop over the center. Ok not the best answer but that is what i did. Be carefull
I installed my bezels last year and put my face plates on this weekend... it doesnt matter cause the where the faceplates are installed is a differant part then then where you put your bezels.
Thanks Steve, I will try to gently pop them over the needles. Would you mind answering a couple more questions?
1. What wires to you connect the converts too and where are these wires located?
2. Should I reinstall the OEM guage lights that are located on the sides?
3. Did you take remove the gauges to install the new face plates?
Thank you again for your help!
Banned Scam/Spammer
We can do a lot to them. Contact me with what you're looking for.
Banned Scam/Spammer
Connect the Red wire from the inverter to the Dark Blue wire coming out of the Dimmer Switch pack and the Black wire to Black.
Cruise-In 9-10 Veteran
St. Jude Donor '08-'09-'10
at least i have xtremevette fixing mine now
