Carbon Fiber wrapped interior
#81
1 Post
St. Jude Donor '12
The film does come with its own adhesive backing. I think you're refering to the primer. The primer is only needed where contours and curves require the film to be stretched, which makes it want to lift off of the contact surface. I also primed the areas behind the edges where the film tucks behind.
#83
I make alot of real carbon fiber overlays, but I think I may start using this. I have been curious as to how it would look. I think if I cleared it I could get the depth of real CF. All I know is that sanding it for hours just got plane old to me. This looks alot easier and cleaner to work with. Glad I saw this thread b/c im pretty much going to do this now.
Thanks!
Thanks!
#85
1 Post
St. Jude Donor '12
Here's why: It will be pretty tough to stretch the small amount of material that will be available from the lower fascia that covers the oblong openings, let alone enough to tuck material onto the unexposed side to assure a good tight edge.
#86
I would do it in 2 steps. First do the inside ring surface, then follow with the lower fascia and blend into the rings.
#87
1 Post
St. Jude Donor '12
That's what I would do...Your call though. Good luck.
btw...I'd love to see some pics when done! - C.A.
#89
I have a question for the OP. How much does the vinyl stretch? I think this would be great for the brake duct scoops, but I think it will need to be stretched a little bit to cover the inside contours. What do you think?
#91
thats a good idea. Id like to see what the OP says about this. Im about to order some off the auction and get some extra material to try some different stuff around the car.
#93
1 Post
St. Jude Donor '12
The material will stretch quite a bit when heated. I'm sure you'll be ok with the rear brake ducts. That said, I'll take a look this weekend at my buddy's Z06 and let you know what I think about covering those pieces. Stay tuned... - Mike
#94
Here is a pretty good example of its abilities.
http://forums.corvetteforum.com/c5-g...post1574788723
I was thinking about doing the brake ducts too but not sure if I want to mess with taking the screens out to make it easier and look overall better.
#95
1 Post
St. Jude Donor '12
PM sent
#99
I know, im bringing an old one back, but a year later how does this look? did it hold up okay? this looks like a good way to do this, lets see some more pics of those who have done it!!
