Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-02-2010, 03:44 AM   #1
dlquackenbush
Junior Member
Default Cleaning Engine Bay
Hi, I am looking for some assistance in how to best clean and detail my engine bay. My 04 CE Z06 is registered for Gold Certification at Bloomington Gold in just a few weeks and I'd like to know how to best approach cleaning the engine compartment without putting a hose to it.
Diane Quackenbush
dlquackenbush is offline   Reply With Quote
Old 06-02-2010, 05:22 AM   #2
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Just how dirty is it? On mine, I just wipe down the surface area with a moist Absorber (synthetic chamois) and if there is any grease, I use a little Simple Green on a rag to wipe that area up. I also use an air compressor with a nozzle to blow dust/debris off the engine/suspension area.
Vetteman Jack is offline   Reply With Quote
Old 06-02-2010, 05:59 AM   #3
dlquackenbush
Junior Member
It's probably not all that bad but there are over 17k miles on the car so it's not like it has never been driven. I don't have an air compressor but I do have a blower. I've heard of Simple Green but never used it. Does it need to be rinsed off? I'm afraid to take a hose to it because...well, it's probably not a real good idea.
Old 06-02-2010, 06:55 AM   #4
hb4lthr
CF Senior Member
hb4lthr's Avatar
Don't be afraid of the hose. I actually got the idea from Adams Polishes in one of their earlier videos on how to clean the engine bay. Here's what you do:
1) Spray the engine bay with some form of degreaser or all purpose cleaner. I use 409.
2) Using a soft brush agitate the dirtier portions of the engine.
3) Before turning the hose on to rinse, start your engine. Then and only then, turn on a very light stream of water to rinse it off. The idea behind turning the engine on is if you should see your engine begin to sputter, move the hose off. I have never had my engine sputter.
4) Use a leaf blower to blow out the remaining the water.
5) Wipe down the remaining wet portions.
6) Dress the plastic with your choice of exterior trim treatments
I have used this process on all my cars with no problems
hb4lthr is offline   Reply With Quote
Old 06-02-2010, 07:58 AM   #5
RSchleder
CF Senior Member
RSchleder's Avatar
I agree with hb4lthr, good process. Don't worry about a fine spray of water on your engine, it's designed to tolerate it. You can scrub all day and all night with a rag/brush and it still won't be a clean as a little degreaser/water treatment.
RSchleder is offline   Reply With Quote
Old 06-02-2010, 08:03 AM   #6
Dr. Dan
CF Senior Member
Support Corvetteforum!
Dr. Dan's Avatar
Just be careful that no water gets into the recess of the rear knock sensor as it will short out and need to be replaced. There is a TSB on this issue. I found out the hard way.
Dan
Dr. Dan is offline   Reply With Quote
Old 06-02-2010, 10:08 AM   #7
99 VET
CF Senior Member
Oldtimer
I use a bucket of water with some Simple Green in it & wipe with a wet rag. I like to get some detail spray on a rag & wipe the hoses after I'm done, leaves a nice gloss. Good Luck!
99 VET is offline   Reply With Quote
Old 06-02-2010, 10:49 AM   #8
jrose7004
CF Senior Member
jrose7004's Avatar
I just use a damp rag and work at it.
jrose7004 is offline   Reply With Quote
Old 06-02-2010, 11:48 AM   #9
khblair
CF Senior Member
Cruise-In 9-10 Veteran
St. Jude Donor '08-'09-'10
Quote:
Dan
where?
khblair is offline   Reply With Quote
Old 06-02-2010, 03:10 PM   #10
Dave68
CF Senior Member
Dave68's Avatar
Location: Member: Double Yellow Dirt Bags San Diego, CA
I believe the knock sensor is behind the intake manifold (pain to replace, as is the similarly-positioned smog pump check valve). But regarding cleaning the engine. I spritz some water and simple green solution and then wipe off with paper towels.
I stayawy from using the hose for reasons stated above.
__________________
2001 Mag-Red Coupe 6-Speed, 1SC, Z51, Born: May 17, 2001, delivered June 7th, 2001
315.9 RWHP 337.7 RWTQ (Dynojet) 6/8/02 (no mods)
328.8 RWHP 352.2 RWTQ (Dynojet) 5/22/04 (mods listed below)
Quad Round Borla Stingers 9/6/03
Halltech Stinger-R intake system 4/17/04
Cold-air scoop mod 5/20/04
TPS Z06 shifter (replaced BPP on 12/26/11)
Intake install, oil trap, and CAI mod: http://www.conceptualpolymer.com/corvette_c5_corner.htm
Dave68 is offline   Reply With Quote
Old 06-02-2010, 03:42 PM   #11
dougbfresh
CF Senior Member
The 2 knock sensors are UNDER the intake, that's why water is a problem. It can pool under the intake and get into the wells where the sensors are.
dougbfresh is offline   Reply With Quote
Old 06-02-2010, 06:08 PM   #12
Stock Man
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10
Stock Man's Avatar
I just use the air compressor to blow out the big stuff. Then on to a damp rag, and if you want dampen it with something you don't mind using. Then dry off with a clean rag. It will sparkle. If it doesn't meet up to your expectations then you will have to get more aggressive. But I am pretty sure you won't have to go to that far. The engine bay cleans up quite well.
Stock Man is offline   Reply With Quote
Old 06-02-2010, 10:21 PM   #13
Michael b
CF Senior Member
Michael b's Avatar
aerospace 303 awesome stuff.... Do a search online for it. Been using it for 10 years and worth every penny.
Michael b is offline   Reply With Quote
Old 06-02-2010, 11:33 PM   #14
Silverbullet00
CF Senior Member
Silverbullet00's Avatar
Location: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Adams In n Out spray after you clean it! Awesome stuff! Shines all the plastic and goes away by itself on the metal surfaces.
Silverbullet00 is offline   Reply With Quote
Old 06-02-2010, 11:55 PM   #15
0331MARINE
CF Senior Member
0331MARINE's Avatar
Location: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Send a message via AIM to 0331MARINE Send a message via Skype™ to 0331MARINE
Simple green mixed with water in a spray bottle Never had a single problem in 3 years.
0331MARINE is offline   Reply With Quote
Old 06-03-2010, 12:04 AM   #16
warpster
CF Senior Member
warpster's Avatar
You shouldn't really use Simple Green as it is somewhat corrosive to Aluminum. Simple Green also makes EXTREME SIMPLE GREEN AIRCRAFT CLEANER that is formulated for Aluminum, works great!
warpster is offline   Reply With Quote
Old 06-03-2010, 12:28 AM   #17
0331MARINE
CF Senior Member
0331MARINE's Avatar
Quote:
Well then when it eats away my motor, a bigger one will replace it!!! Like I said 3 years no problem. I've used it on every car I have had. I spray it down, then spray with 2 parts water 1 part simple green. Then I spray it off and dry it!
Old 06-12-2010, 10:39 AM   #18
dlquackenbush
Junior Member
Thank you for all your responses. I'm going to try to locate the Extreme Simple Green and the Aerospace 303.
Thank you all VERY MUCH!!!
Old 06-12-2010, 09:09 PM   #19
philliesphan101
CF Senior Member
philliesphan101's Avatar
Quote:
philliesphan101 is offline   Reply With Quote
Old 06-13-2010, 04:00 AM   #20
clayton1
CF Senior Member
clayton1's Avatar
TheBigEarl85
You probably dont want to hose down a hot engine with cold water either.
clayton1 is offline   Reply With Quote
Reload this Page Cleaning Engine Bay
Tags
1997, bay, c3, c5, clean, cleaning, compartment, corvette, detailing, engine, hareware, pictures, service, sputtering, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
