Anyone running full LG 3" exhaust?
Hi everyone,
Just looking for some sound clips and some helpful advice on running the LG Pro long tubes, X pipe, and 3" CBE. I did see the youtube clip of just the LG 3" CBE, but I'm wondering how it will sound with the headers and X pipe as well.
Also, what's the advice on running a full 3" system on a (for now) stock LS6? Will I lose a measurable amount of hp/tq. on the low end without the backpressure?
I'm planning on having the Vararam by then and possibly a Whiplash II cam installed at the same time of the exhaust (since they'll both require a tune).
Thank you for the help!
Hi everyone,
I can't help you on the exhaust. I'm running TSP 1 3/4 headers, stock TI exhaust with DHM electric cutouts(worth around 10hp)
I'm going to say I really feel on the axle back side the actual flow rating of the muffler is the biggest concern but I would imagine that 3" LGs would still create sufficient backpressure to not completely kill low end torque. The design of the headers themselves are more tailored to power under the curve than peak numbers, if anything the 3" might give you some more peak numbers. Either way LG does significant testing on their products, so I'd say they would be the ones to ask for their recommendation. I say buy the upgrade for future mods, even at the sacrifice of some numbers now. Your car is still going to run way better than stock with a full 3 inch system and will only benefit more from future upgrades.
My car is at England Green right now having a cam installed. Are you running the stock rear end/gears? The Mayhem II cam is going to make more torque than the whiplash cam. I've got a built rear end and I'm drag racing the car. I decided against the Whiplash on the stock block. I spent a lot of time talking to Stephen and Jason at the shop, and I think you might want to talk to them about that cam. It should make similar HP numbers, and will probably work better if you are running the stock gears.
Thanks.
1 Post
Here is my buddy's car. 2001 Z06, stock displacement, Blackwing cold air, trick flow heads, fast intake, lg g5x3 cam (114), lg pro long tubes 1 7/8's, x pipe, lg Big Three 3" over axle, and high flow cats. Full 3" exhaust from the headers back. I might have missed a few mods, but you get the idea. The exhaust isn't obnoxiously loud like some, but it does create a lot of interior resonance. You can't really drive in 4th gear at regular city speeds, it's just too boomy. Full throttle is really awesome though!
http://www.youtube.com/watch?v=ybyqSn88Bx0
Oh, and the exhaust back pressure measured out to be 1.5 pounds on each side for this particular application. The stock titanium system tested 3 pounds one side and over 5 on the other. It was thought that the muffler baffles on the one side were somehow comprised.
Nice car he has there!
He should take some if he doesn't
Life Time NCM #2196
http://www.youtube.com/watch?v=9miUQ...layer_embedded
