Woke up my COW Tune?
2001 Coupe - A4 - 45,000 miles
Sent my PCM off to Chuck COW last XMAS for him to work his VooDoo on it. Installed it in January and noticed an immediate improvement in drivability - especially 2nd gear, but not a lot of difference in 1st gear unless I got on it really hard (i.e. not much difference in 1st gear on a normal start).
This past week I had to take my car in under GMPP for some warranty work. One of the things on the list was to repair a minor transmission leak - I was getting one drop of fluid on the floor every night for the past few months and it took 2 months for them to get me in. Just picked the car up this afternoon. I started the car up at the dealership, put it in gear, barely touched the gas and it was like the car was rocket powered! I am guessing that installing the new transmission bushing and seal together with changing the trans filter and fluid, must be what made the difference? This sucker is "screaming" now!
They did some other work, but not sure how any of that would affect shifting performance?
They also...
• Replaced EBCM
• Replaced Fuel Filter
• Replaced Left Tank Fuel Level Sensor
• Replaced Windshield Washer Tank Sensor
I had them replace the trans fluid at 20k miles, but they did not replace the trans filter - so maybe it was the trans filter that was shot?
They also...
• Replaced EBCM
POSSE SENIOR RIDER
I had Chuck tune mine at his shop a year ago. I also added GHL Bullets and a Vararam.
Chuck does a great job and the results are impressive.
Our group went to a dyno day Saturday and these are my results:
322.6 rwhp @ 5581 rpm/149.7 mph
322.4 rwtq @ 5137 rpm/137.4 mph
quarter mile: 12.61 @ 109.6 mph
Not bad for an otherwise stock 2002, A4.
Have fun with yours.
Received 19,423 Likes
'20-'21-'22-'23-'24
Whatever was the problem, sure is good to have it resolved. Enjoy that new found power.
St. Jude Donor '08
I was thinking the same thing because I know most dealerships will do this. However, I have also heard that ChuckCoW locks the PCM after he tunes it, which I think is ridiculous, so I dont know if the dealer would be able to get into it without some sort of passcode?
I have looked at this 1st gear deal myself and have some ideas about what you were noticing.
When I have the trans in D and slow to a stop, it feels like the tranny is starting in 2nd and not downshifting to 1st. Not sure if this is the factory programming method but the car launches way better if I mannually shift into 1st.
Before anyone jumps in and disagrees, I have counted the shifts and for sure this is what happens. Doesn't bother me but it did make me wonder. It does the same thing if I slow while downshifting from D to 3 to 2 and stop. The tranny will not downshift to 1st on its own.
There is not a problem pulling away in 2nd, car drives normal.
One thing I do like about the reprogram is that at certain RPM if I get off the gas, like slowing to get into a quick turn, and then nail the gas, it seems like the tranny is just waiting for me to nail it and then it downshifts. This is not the normal mash the gas downshift, it's different in a good way. It's like having a manual and doing the slow-down, clutch-in, down-shift, turn, nail-it in the lower gear accelleration fun.
I know that Chuck doesn't probably want to reveal all of the magic but maybe shed a little light on the intended tranny performance of the A4 tune?
Chuck?
Chuck?
Bazinga!
Got a Chuck Cow tune last year at Carlisle, along with headers, but the tune seem to wake this thing up. The shift points in the tranny are ideal for me, and as stated above going into a turn and coming out of a turn is a lot more pleasant, you don't have that sluggish feeling while coming out.
Chuck CoW FTW
Chuck CoW FTW
Either that or the windshield washer sensor replacement
In all seriousness, one of the coolest things about hptuners is the ability to "tweak" your up shift / downshift points to make the car feel peppier. It's easy to get "lost" and have to start over, but it sure makes your car shift to your liking.
A Tuner can turn off TM and make sure the PE delay is off, and make a car, especially an auto, seem like a different ride
They also...
• Replaced EBCM
• Replaced EBCM
If they re-flashed the PCM, then that could alter the performance characteristics.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
You are correct.....
Yes I can...And YES I have.....Special CARS & SPECIAL CIRCUMSTANCE only.
The regular mail in tune or customer that comes to the shop for a tune, or meets me on one of my tuning trips.... NEVER has to worry.
It's where it's a special build or work in progress for a new product or cam.....But again, regular customers...NEVER.
Chuck CoW
Chuck CoW
Get more information about how it is performing and talk to Chuck.
I don't think there is any chance that the dealer could improve performance ovr a COW tune, especially on the transmission. If they reflashed the EBCM I don't see anything good happening.
oops, looks like Chuck already checked in.................
