Simple but effective visual cleanup!
Every time I look at my car one item sticks out like a sore thumb, the windshield wipers. They were pitted, chipped and faded. I used an automotive/outdoor satin finish black to clean these up.
I did the usual sanding and cleanup before spraying about 4 coats of paint. Not so bad if I say so myself. The paint was $2.50 but the wiper "puller" was about $13. I'll have to ask Patrick or Gene at GMParts if they have those end caps.
Before:
After:
Before:
After:
i replaced my cowl with a new oem one from Gene Culley at gmparts house. even replacing it with a stock one does a lot for the looks of the car. you may want to just remove it and see what some armor all will do for it before you decide to toss it for a new one. painting is probably also an option.
Received 1,675 Likes
Looks much better.
I just started using 303 myself on random stuff, and it really does bring back some nice luster/shine.
Worst case, I would go with Gene for a new one, and a amazing person to work with.
