what year to buy ?
C5 Yearly differences in models
1997
• Completely new, redesigned Corvette. Base (FE1) and Z51 (FE3) suspension packages.
• All Z51 cars include: Power Steering Cooler, xx, xx, ??
• 97-00 C5 LS1's produce 345 HP @ 5600 RPM and 350 Ft Lbs of torque @ 4400 RPM.
1998
• Convertible becomes available
• Active Handling becomes available late in year
• The two slots of a 1998 (and possibly late 1997s) curve toward the rear at the bottom. (versus straight down)
1999
• 26# injectors substituted for 28#
• Fuel pump revised to reduce noise
• FRC "Fixed Roof Coupe" aka the hardtop, becomes available. All FRC's are MN6 (6-speed) cars with the Z51 suspension package, and are about 60lbs lighter than coupes.
• HUD introduced
• only one line in driver's side fuel rail cover (no fuel return line?)
• Power telescoping wheel becomes an option
• ? Steering hardware changed to combat wandering
• door sill trim plates added
2000
• Millennium Yellow available
• ? "Thin Spoke" versus "wagon wheel" design wheels become standard.
• Pup cats added to CA models for LEV emissions requirements (5hp loss relative to 97-99)
• Steel swaybar endlinks instead of plastic on Z51 equipped cars
• Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06)
• No keyhole on passenger side doorhandle
• Passenger airbag 'off' switch added to console (light by TC/AH button)
2001
• return to 28# injectors for all models.
• Second Generation Active Handling
• Nassau Blue discontinued
• Alternator 'clutch' pulley added on A4 cars
• New soundproofing + foam in all cars
• Smaller keyfob
• electrochromic dimming rearview and driver's mirrors
• lighter AGM battery
• Thickness + Material in vert change
• Chrome exhaust tips for coupe + vert
• 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
• LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
• All Corvettes now have the LS6 intake manifold
• All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
• LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
• Hardtop/FRC discontinued
• Pup cats added to all models
• Stronger synchros in all transmissions
• Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
• metal valvestem caps (late year)
• Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in dia from 55 to 63 mm.
• Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
• Introduction of the Z06, which has as differences:
o hardtop body style
o rear brake ducting
o screened inlets on front fascia, without foglights
o F1 supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
o new LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
o M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
o Titanium exhaust system
o lightweight windshield
o New, stronger clutch with redesigned master + slave cylinder
o Stronger rear differential (shotpeened ring gear)
o Red brake calipers (otherwise identical)
o Trans overtemp warning light on DIC
o 6500 redline gauges with special checkering + Z06 font
o redesigned PCV system to help combat oil burning
o Red LS6 Fuel Rail Covers (FRC's)
o FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2002
• Z06 Changes:
o Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5
o Less restrictive intake airbox lid
o Descreened MAF
o Removal of pup-cats (total with changes = 405hp)
o Z06 shocks revised with less rebound for better launching
o Z06 brake pads revised for better stopping (generate more dust)
o Lighter, sodium filled valves w/ stronger valvesprings
o higher tension rings installed to prevent oil burning problems
o slight piston redesign *
o clutch strength upgraded.
o HUD available on Z06 (not avail '01 model year)
o Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical
• Electron Blue color offered
• Steel endlinks changed to aluminum
2003
• Late model-year new fuel system design from C6's
2004
· Z06 shocks further refined. Accompanying upper front control arm bushing, and rear swaybar bushing changes.
1997
1998
1999
• HUD introduced
2000
2001
• Smaller keyfob
2002
• Z06 Changes:
o Descreened MAF
2003
2004
Now that is some great info . thanks!
One minor correction that was pointed out to me, the new fuel system was installed in late '02 after the first 5 months of production.
http://forums.corvetteforum.com/1571706441-post12.html
http://www.c5registry.com/MembersOnl...2003/index.htm
My car was produced in Dec '02 and I have the new fuel system. Not nitpicking here but over half of the '03s had it.
You can look in the glove box for RPO code FFS. It was changed to comply with new emissions standards and is shared with the XLR and newer Corvettes. The design may have carried forward to the C6 but this was just to comply with more regulation, not to make it better for you.
Everything including the filter is in the tank, not user friendly if you have to replace stuff.
Thanks 03WC, didnt know that It was just a text version of the changes that Ive seen posted often (this comes up a lot )
I ammended the copy of the file I use to say (started late 2002), but with the conglomeration of minutia one collects over the years its no better than even money that Ill find the corrected file the next time I go to post it
Received 19,393 Likes
'20-'21-'22-'23-'24
For me, I'd choose the lower mileage car and then put things on that you want as you can afford them.
Changes for 2003
Wheel Locks are no longer provided
Early production convertibles had one gas strut for the trunklid, later models got 2
Late production 03's got an improved fuel system
DuPont softened the paint formula on all 03's to try to limit rock chips
03 was the 1st C5 to offer a dash color other than black (shale in 1SC cars)
RPO 1SC - a 50th Anniversary Edition was offered (not in Z06 trim), the 1SC option and accounted for 1/3 of 03 production
Spiral Gray - new color
RPO F55 - magnetic suspension was available (std on 1SC) Countless dealers fail to remove the shipping blocks (shock stuffers) on F55 equipped cars, resulting in harsh ride
Factory and Museum News - 50th Celebration, JD Powers award, Museum 10th Anniversary, VIN raffles, Cadillac XLR begins production at BG, A change from Cave City Chevy to the Museum for R8C PDI (Pre-Delivery Inspection), C5R Undefeated 2003 Season
Cruise-In IX Veteran
In my opinion I would stick with an 01' or newer. Based on my research it appears that the most adjustments and upgrades were done in 01'. So I would say the lowest mileage 01' or newer you can find. There are some really nice cars in this range out there. I would try to find a car with the fewest owners as possible too. This is not a deal breaker because there are cars available that have been passed along to several owners and they have been treated very well. It seems though that the more hands a car passes through during it's life time the more likely it is to become neglected. I would also recommend a carfax or something comparable as an absolute requirement. It doesn't cost that much and can reveal an ugly past. Just gives a little peace of mind. That's my 2 cents.
1997
1998
1999
• HUD introduced
2000
2001
• Smaller keyfob
2002
• Z06 Changes:
o Descreened MAF
2003
2004
1997
1998
1999
• HUD introduced
2000
2001
• Smaller keyfob
2002
• Z06 Changes:
o Descreened MAF
2003
2004
Some good points, but also some errors and missed points. For one Z06s and Coupes/Verts never shared the same block.
Also 2001-2002 Z06s, there were more changes than listed such as sodium filled valves.
Suggest buying a Corvette Black Book, lots of useful info in there. No matter what year C5 its still an amazing car.
Don't be shy of the late 03's and 04's due to the cross over leak. Only a small percentage of Vettes experience this, and even still Chevrolet is now covering the repair for 10 years total after original purchase date. So for the next 4 years GM will cover it.
Received 1,101 Likes
By that I mean some 04's, not all. Don't think any 03's are included unless GM did a 180. There's a long discussion on 'cross-over' topic which has the current status.
#33
I looked at options, mileage, condition. Year model was not a issue as all C5's basically look the SAME...
I looked for several months and I finally found the perfect car 400 miles away. I paid a premium for a clean, garage kept, never driven in the rain, adult owned and driven, clean carfax, no accident C5. My car had only seen the dealer twice. Seat Belt and Column Lock. No issues!
My 98 was listed for $22,500 and after 3 weeks of going back and forth, I paid $20k and ended up with a immaculate 17,500 mile 1998 C5 Coupe.
Best of luck in your search! There are a lot of C-5's out there with 1 to 300k miles on them. Just remember, you may save a few bucks by settling for a high mile Vette, but, you could more than make up the difference in repairs. Food for thought
#37
That was just an example.
