Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-15-2010, 12:05 PM   #1
IDM
CF Senior Member
IDM's Avatar
Default Stuck CD Changer Magazine
Guys I bought a cd changer and magazine and when it arrived the magazine was installed all the way.
Now I cant get it to eject even with power is there a trick?
Im guessing something happened in shipping?
IDM is offline   Reply With Quote
Old 04-15-2010, 01:21 PM   #2
rickko
CF Senior Member
rickko's Avatar
When you apply power to it with the disc carousel door completely closed, does it go through a startup routine where you hear what sounds like its loading each disc tray? The process takes about a minute to complete. The door has to be completely closed. If you don't hear that happening then I think you have a faulty player right off the bat. After the cycle completes then you should be able to open the door, wait a few seconds and then carousel should eject automatically.
..rickko..
rickko is offline   Reply With Quote
Old 04-15-2010, 02:12 PM   #3
Aerovette
CF Senior Member
Aerovette's Avatar
...and don't lay it flat. It doesn't like that too much.
Aerovette is offline   Reply With Quote
Old 04-15-2010, 02:23 PM   #4
IDM
CF Senior Member
IDM's Avatar
is there a way to manually eject it ?
Old 04-15-2010, 04:37 PM   #5
IDM
CF Senior Member
IDM's Avatar
anyone guys?
Old 04-15-2010, 04:48 PM   #6
DeltaBravo
CF Senior Member
Support Corvetteforum!
DeltaBravo's Avatar
Try turning it on its left end when looking at the front/door side. Then with power applied open the door. If there's a magazine tray stuck in there (happened to me twice), gravity will help it reload into the magazine, which should then pop out normally.
This isn't my idea, but I can't remember who posted it so I can give him/her props for it!
Dennis
DeltaBravo is offline   Reply With Quote
Old 04-15-2010, 05:26 PM   #7
gkohl
Junior Member
I ran into this problem with a couple of units that I bought off of Ebay. Yes, there is a manual eject button. I can't remember the details at the moment. I'll have to take a look when I get home. If I remember correctly, there is a small hole in the upper left corner that you push a paper clip into. This presses on a switch that will eject the cartridge. The door needs to be open and the unit needs to be powered. It doesn't matter what orientation the unit is in. This unit will work sitting flat or on it's side.
If that doesn't work, pop the covers off. There is a lever inside that is impossible to describe here that you push on to release the cartridge. I had a problem with one of them where a disc got stuck inside the unit but I can't remember how I got it out. Had to pop the covers.
One of the units that I bought had a small piece of plastic floating around inside that broke off during shipping because the cartridge was not pushed all the way in. This piece came off of the door and was needed so the unit could detect the door being open. Superglue and JB Weld for support and all is good.
I'll recheck when I get home but I think this is correct.
George
gkohl is offline   Reply With Quote
Old 04-16-2010, 12:17 PM   #8
IDM
CF Senior Member
IDM's Avatar
tried the hole with paper clip no go!
Old 04-16-2010, 12:29 PM   #9
rboineau
CF Senior Member
My CD changer cycles when a disconnected battery is re-connected. Probably won't help you, but worth a try as it might shake something loose. Good luck
rboineau is offline   Reply With Quote
Old 04-16-2010, 12:32 PM   #10
IDM
CF Senior Member
IDM's Avatar
I could just unplug the changer and plug it in to do the same thing no?
Old 04-16-2010, 01:08 PM   #11
AUandAG
CF Senior Member
AUandAG's Avatar
Remove the outer case (6 screws) completely. Look for a white plastic piece on the bottom of the unit. Move it with your finger to eject the cartridge manually.
AUandAG is offline   Reply With Quote
Old 04-17-2010, 09:10 AM   #12
IDM
CF Senior Member
IDM's Avatar
So that should do it ehh...
Old 04-27-2010, 06:06 PM   #13
gamisou
CF Senior Member
gamisou's Avatar
Here's proof you took apart my perfectly good CD changer Ill refund your $10 you spent shipping it back to me all ****ed up with the magazine half pried out.
gamisou is offline   Reply With Quote
Old 12-07-2013, 02:05 PM   #14
Electron Blue
Junior Member
Electron Blue's Avatar
Default CD Changer Stuck
My Pioneer 12 CD changer is the original in my 2002 vet, never had a problem until now. I could see slot 7 tray would not retrack back into the tray, so the tray would not pop out of the changer. The little button in the upper left corner does cycle the unit to try and reload the CD's, but with one stuck, it would not work. I had to remove the unit from the car (6 screws - 3 on each side). I removed the top and bottom case of the CD player (6 more screws). This will not give you access to the CD tray holder, but I could clearly see a CD was stuck on the platter. I connected the unit up to the vet again and hit the reset button with a paper clip. This time I could clearly see there were two disks on the platter. I kept hitting the reset button while turning the unit. Turning the unit upside down made one of the disks fall back into the holder. With only one disk on the platter I could now see the unit move up and down against the tray. I kept hitting the reset button until the unit moved up to the top slot - tray 12. Once there I reset it again and the tray popped out. I unplugged the unit and was able to remove the stuck CD from the platter through the opening where the tray sits. Common sense tips that I forgot to follow... don't leave CD's in the changer for 5 years... especially in Florida. Don't put paper labels on CDs that you burn - one more thing to get stuck.
Electron Blue is offline   Reply With Quote
Reload this Page Stuck CD Changer Magazine
Tags
1997, 2001, cartilage, cartridgecorvette, cassette, cd, changer, corvette, disk, jam, jammed, magazine, player, stuck, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
