Light Is Off But Someone Is Home
http://forums.corvetteforum.com/pict...839438&thumb=1
I Just Moved Up From A C4 to This C5 This Week.
2004 Looks And Runs Great 28000 Miles
The Hood Light Will Not Come On, I Replaced The Bulb And Other Ideas?
You can voltage test the socket at the waterproof plug connection below and also at the light itself - start there!
Thanks,Matt
Thanks,Matt
check to see if the lights on your rear view mirror work. if not, its probably a fuse. I heard these two items run off the same circuit. hope this helps.
-Dan
-Dan
Received 19,436 Likes
'20-'21-'22-'23-'24
Good things to look at mentioned here. Hope it is something as simple as a loose connection or, blown bulb or a blown fuse.
Received 2,122 Likes
Fuse #2
