spray touch up 99 pewter
Trying to find a spray can of 99 pewter paint. Want to use it to paint a lic plate trim piece. Anybody know of venders that sell this? thanks
Try googling R&E paints, they can match the color code of your car and put it in a spray can for you. I bought some MY from them twice and it looks really good.
Russell
Russell
I used Dupli-color T408 pewter on my surround and it's real close, you can't really tell. It's a truck, van & SUV number. Hope that helps.
I did as you said, sanded a bit, cleaned with a final wipe of alcohol. I did use a sanding primer. Dupli-color also makes a spray adhesion promoter that's suppose to help with that black plastic. I didn't find that until I was done. I haven't had any problems so far.
Received 19,420 Likes
'20-'21-'22-'23-'24
Here are some good vendors for spray paint:
• www.corvettepaintcodes.com
• www.expresspaint.com
• www.paintscratch.com
Also, http://www.drcolorchip.com
Shoot 1 coat DupliColor Pewter Metallic T408.Let dry 24 hrs. Wet sand lightly w/600 grit paper. Rinse with clear water. let air dry. Wipe w/ lint free rag. Again, don't touch front with bare fingers. Shoot 2nd coat T408. Let dry 24 hrs.
Wipe with a lint free rag and shoot with DupliColor Clear T125. Let dry 12 hrs.
DON'T get antsy. Let dry as above. If you don't, the coats will get cruddy and orangepeel. I did mine over 2 1/2 years ago and today it still looks new and factory fresh.
ordered paint
Well went down to order the paint. Stuff was on sale, got the paint, adhesion promoter, and clear for less than $14.00. Can't beat that. Thanks again
I painted mine 3 different times and always had cracks and peeling paint. Someone ran into my front fender and I had them paint it when i had the bodywork done and now it's perfect.
Anybody needing paint in a spray can that matches their color should be able to go to their local automotive paint supplier. They can mix the factory color and most have the capability to put it in a spray can. You would still need a clear to apply over the paint.
