Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-22-2010, 06:47 PM   #1
Stan MI
CF Senior Member
Stan MI's Avatar
Default Carpet under tires - Winter storage ??????
Was going through some posts about Winter storage and came across several posts that say to place a piece of carpet under each tire while the car is in storage. None of the posts say "Why" to do this.
I store inside, on concrete and it does get below freezing and I do sometimes heat the area.
Just want to make sure I'm doing what's best for the car.
Stan MI is offline   Reply With Quote
Old 01-22-2010, 07:10 PM   #2
0Brian@FI Performance
Former Vendor
Brian@FI Performance's Avatar
Location: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
Send a message via AIM to Brian@FI Performance
Never heard of that. You usually see carpet at dealers to protech time floors from rubber staining.
Brian
Brian@FI Performance is offline   Reply With Quote
Old 01-22-2010, 07:13 PM   #3
LiteraCola
CF Senior Member
LiteraCola's Avatar
I've always heard that putting a piece of thick carpet under each tire does a pretty good job protecting your tires from developing flat spots while sitting in storage. Other than that, I see no reason...
LiteraCola is offline   Reply With Quote
Old 01-22-2010, 07:15 PM   #4
dquagliaroli
CF Senior Member
St. Jude Donor '09-'10-'11-'12-'13
Support Corvetteforum!
Default Cement
Ever leave a battery on a cement floor when it is cold out??
Have a car that I leave in Florida and if I don't keep carpeting under tires they loose air and form flat spots.
dquagliaroli is offline   Reply With Quote
Old 01-22-2010, 07:20 PM   #5
allngn_c5
CF Senior Member
allngn_c5's Avatar
I don't use carpet and I've never had any issues. I do however roll the car out once a week to help prevent any complications.
allngn_c5 is offline   Reply With Quote
Old 01-22-2010, 07:32 PM   #6
2KFRC5
CF Senior Member
2KFRC5's Avatar
The pieces of carpet are just pads to hold the large, thick piece(s) of plastic that you parked your car on. It's a moisture barrier for storing. If, you are concerned with moisture.
2KFRC5 is offline   Reply With Quote
Old 01-22-2010, 07:35 PM   #7
Blown 346
CF Senior Member
Blown 346's Avatar
With the tires these days, letting your car sit thru winter will not harm the tires or cause flat spots. My car sits for 5 to 6 months and my tires have never gotten flat spots.
Like said above, carpet under the tires is to stop staining on tile. If your garage floor sweats and builds up moisture when cold. I would place a piece of carpet under the full length of the car. That moisture under the car will attach to the bottom of the car and can help rust.
Blown 346 is offline   Reply With Quote
Old 01-22-2010, 08:11 PM   #8
stingraymyway
CF Senior Member
St. Jude Donor '09-'10-'11-'12-'13-'14
stingraymyway's Avatar
Location: Out of Site...Out of Mind. Corvette: anything else is just transportation.
Quote:
I guess it depends on how long the car has to sit in storage.
stingraymyway is offline   Reply With Quote
Old 01-22-2010, 08:22 PM   #9
jrose7004
CF Senior Member
jrose7004's Avatar
Jim Rose Jim Rhttp://www.linkedin.com/profile/view?id=89789687&trk=hb_tab_pro_topose
Todays tire really don't develope flat spots.
jrose7004 is offline   Reply With Quote
Old 01-22-2010, 08:29 PM   #10
rebelheart
CF Senior Member
rebelheart's Avatar
Sounds pretty **** to me.
rebelheart is offline   Reply With Quote
Old 01-22-2010, 08:34 PM   #11
Hammer99
CF Senior Member
I put 40psi in each tire and don't worry.
I keep garage at 50 deg.
Hammer99 is online now   Reply With Quote
Old 01-22-2010, 08:41 PM   #12
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Location: Jefferson City, MO Sometimes common sense isn't so common.
Quote:
That's the reason I do it.
Vetteman Jack is offline   Reply With Quote
Old 01-22-2010, 09:10 PM   #13
4 KRUSIN
CF Senior Member
4 KRUSIN's Avatar
I use 2 inch styrofoam under each tire. The advantage is that it compacts to the shape of the tire.
4 KRUSIN is offline   Reply With Quote
Old 01-22-2010, 09:27 PM   #14
Silver Beast
CF Member
Silver Beast's Avatar
I visited a friend of mine who's a Porsche dealer in Connecticut today for lunch, while I was waiting for him I walked around the showroom and noticed that all the cars in the showroom were on pieces of carpet.
I read on the forum about storing a vette on carpet to avoid flat spots but I also read that you no longer have to do that with the new tires these days that the flat spot thing was only for old tires.
My friend explained to me that the carpet helps to keep the floor clean when they turn the tires and also to avoid flat spots on the tires because of the temperature variances in the showroom's floor, being basically concrete, causes flat spots on the tires.
There wasn't a car there for under $100k, if it's good enough for a Porsche it's good enough for my vert, I have carpet under my vert.
Silver Beast is offline   Reply With Quote
Old 01-22-2010, 10:06 PM   #15
Hammer99
CF Senior Member
Quote:
I read on the forum about storing a vette on carpet to avoid flat spots and I also read that you no longer have to do that with the new tires these days that the flat spot thing was only for old tires.
There wasn't a car there under 100k, if it's good enough for a Porsche it's good enough for my vert, I have carpet under my vert.
By chance is that Danbury Porsche? Beautiful showroom...and cars.
Old 01-22-2010, 10:47 PM   #16
RSuperfreak3
CF Senior Member
RSuperfreak3's Avatar
I do it cuz it makes me feel I'm taking care of my baby while it sits in the garage for 5 months. I would carpet the whole garage for my Z if it wasn't for my wifes damn car dropping winter car turds all over hell!
RSuperfreak3 is offline   Reply With Quote
Old 01-23-2010, 12:49 AM   #17
nextime
CF Senior Member
nextime's Avatar
delorean6683
New tires will not develop flat spots, flat spots on tires are a thing of the past.
nextime is offline   Reply With Quote
Old 01-23-2010, 01:06 AM   #18
nmacdonald50
CF Senior Member
nmacdonald50's Avatar
The area where I park my car is fully carpeted. I even have most of the floor in my storage shed carpeted - doesn't everybody?
nmacdonald50 is offline   Reply With Quote
Old 01-23-2010, 01:28 AM   #19
nextime
CF Senior Member
nextime's Avatar
delorean6683
Carpet can hold moisture in a non climate controlled area (garage, shed) and can promote rust! I would never park on carpet unless the area was climate controlled.
Old 01-23-2010, 04:51 AM   #20
Castrellon
CF Senior Member
Send a message via Yahoo to Castrellon
Quote:
I was going to post this. Get a dehumidifier. Use a couple of boxes of baking soda in the interior to wick out moister and absorb stale odors. Put the car up on jack stands if you're worried about flat spots. The car will settle down a few days after you drive it around a bit. Or you can drive it for 50 miles.
Castrellon is offline   Reply With Quote
Reload this Page Carpet under tires - Winter storage ??????
Tags
c5, c6, capet, carpet, corvette, garage, jacks, mobile, protect, storage, storing, tire, tires, winter, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
